Oil pressure help, please
Old Oct 1, 2006 | 09:32 PM
Ricks07's Avatar
Ricks07
Default Oil pressure help, please
Guys-
Bought my first HD last month after riding Honda for more years that I want to count. Its a 2007 StreetGlide and I have about 1700 miles on it now. Today I was on my way home and noticed that the oil pressure went to zero everytime I stopped and then went back to 33psi above 1000 rpm. Before today it went down to just 5psi at idle.
Is this normal? It has Syn3 in it. I love this bike and don't want to ruin it. My dealer is closed today so I can't call and ask them. Thanks for any help!!
Old Oct 1, 2006 | 09:36 PM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
Default RE: Oil pressure help, please
Sounds a little low to me. My '06 S/G will idle at 16-20 PSI when hot. Hopefully your gage is messsed up, not the motor. The good thing is that you have the warrenty to fall back on too!
See what your service dept says before you panic though.
Old Oct 1, 2006 | 09:41 PM
Bryan TTM's Avatar
Bryan TTM
its normal...even tho it looks like zero, it aint...get rid of the syn3 and put some Amsoil 20/50 in it
Old Oct 1, 2006 | 09:45 PM
Ricks07's Avatar
Ricks07
Is the Syn3 causing the low reading gauge?
Pure panic set in the first time I saw the gauge drop to zero....trust me
Old Oct 1, 2006 | 09:49 PM
dawg's Avatar
dawg
Syn 3 just sucks, that's all A good synthetic like Amsoil, Mobil 1 V-twin or Redline will make it run cooler. Also heat management will make your oil pressure drop, if your scoot happened to be going into heat management.
Old Oct 1, 2006 | 09:50 PM
GliderXXX's Avatar
GliderXXX
From the manual: Engine oil pressures will normally vary from 5psi at idle speed to 30-38 psi at 2000 RPM when engine is at normal operating temperature of 230 degrees.
Old Oct 1, 2006 | 10:33 PM
Mr Wonderful's Avatar
Mr Wonderful
Yup.....agree with everyone so far. Lots of riders don't care for the Syn3. Of all the synthetics out there, Amsoil and Mobil1 15w50 seemed to be the most popular on this forum. While you are at it, add a good synthetic hypoid in the tranny, like BelRay.
Don't sweat the gauge.......unless it goes South at 70 mph and 55 degrees!
We all went buggy-eyed at the gauge at idle when we first had our bikes.........we know the feeling.
Old Oct 1, 2006 | 10:37 PM
MACK's Avatar
MACK
AGREE 100% WITH BRYAN. AMSOIL WILL HOLD BETTER PRESSURE AND IS A SUPERIOR OIL TO SYN3.
Old Oct 1, 2006 | 10:48 PM
Ricks07's Avatar
Ricks07
Ok I let it cool down and now it registers 32-33 and stopped dropping to zero.
I read the manual and noticed it said 2-3psi however as soon as I pulled in the clutch, the needle would drop all the way to the zero peg instantly. That is what had me really concerned. I will change out the Syn3
Thanks!!!
Old Oct 1, 2006 | 11:04 PM
2005UltraNC's Avatar
2005UltraNC
Not right - get the dealer to fix. My guess is either gauge or sensor is a bit off.
