Roadking Specs
Old Jan 19, 2011 | 12:46 AM
hatchetman's Avatar
hatchetman
Mine ended the year with around 7 hp. Two blown head gaskets & a leaking intake seal!
But when I release the hounds this spring, I should be around 70 hp with an 80 ci evo.
Hatch.
Old Jan 19, 2011 | 07:04 AM
skratch's Avatar
skratch
Originally Posted by NoCoLoco
Altitude must have something to do with it because the owner's manual says it should have about 92tq stock but even with a stage 1 mine only has 68hp/81tq. I've got a SE Ventilator intake, Jackpot headers and mufflers w/ competition baffles and SEPST. I live at an elevation of 5000 feet. If I had it dyno'd at sea level I'll bet the numbers would be a lot better.
remember, the torque/hp numbers that hd says you should have is measured at the crank, not at the wheel....
Old Jan 19, 2011 | 07:17 AM
blusmbl's Avatar
blusmbl
Yep, all manufacturers publish crank horsepower, not rear wheel horsepower. Altitude shouldn't play too much of a role provided the dyno operator corrects the numbers to SAE specs, of a given barometer and temperature. It won't be completely exact, but pretty close (within dyno to dyno variability, anyway).
Old Jan 19, 2011 | 07:20 AM
nvsteve's Avatar
nvsteve
As stated earlier the factory numbers are taken at the crank not the rear wheel.
I live at 4500' and my stage 1 is at 75hp/88tq. Very average.
Old Jan 19, 2011 | 06:16 PM
NoCoLoco's Avatar
NoCoLoco
Old Mar 9, 2012 | 08:51 PM
MUNDOG's Avatar
MUNDOG
I just got mine Dyno tuned and have the SEPST. All I have is stage 1 with SE Slipons.
my numbers are 75.47HP/82.15TQ. I was also wondering what the stock #'s were. I was told these are average for stage 1. any suggestions?
Old Mar 9, 2012 | 09:56 PM
therocket's Avatar
therocket
Pre-Upgrades on my 96 to a 107 cu in on my 2011 Road King was 62HP and 82FT/Lb torque at the rear wheel on the dyno with Rinehart 3.5 slip-ons.
Old Mar 10, 2012 | 07:46 AM
scottmotorsports's Avatar
scottmotorsports
This is for the 2001 off of this site.
http://www.totalmotorcycle.com/photo...ingClassic.htm
Specifications:
Engine Type: 1449 cc, 4-Stroke, Air Cooled, V-Twin
Engine Bore and Stroke: 95.3 mm x 101.6 mm
Valves 2 valves/cylinder
Claimed Horsepower: 67 hp (50 kW) @ 5200 rpm
Maximum Torque: 110 Nm (81.1 ft. lbs) @ 3100 rpm
BrianSF-GA
Dec 5, 2012 08:28 AM
Tooth
Aug 24, 2011 12:16 PM
5windows
Jul 20, 2011 02:20 PM
sgdiesel
Dec 4, 2010 07:54 PM
myxcape
Dec 3, 2010 08:04 AM
