Anyone have problems with LRS shields Fitting?
Old Jan 19, 2011 | 07:03 AM
  #31
riteway's Avatar
riteway
Originally Posted by 1flhtk4me
I think a Dremel tool would work better than a drill bit.Drill bits are not meant to be used for side cutting.
Yes, Yes, Yes!!!!!!!
Originally Posted by Watch Guy
then just re drill the holes to fit. Pretty easy stuff to cut through.
No, No, No!!!!
Old Jan 19, 2011 | 01:00 PM
  #32
Ribitt's Avatar
Ribitt
got the 8" ultra and it fit with no problem and love the shield.
Old Jan 19, 2011 | 05:53 PM
  #33
woodhog17's Avatar
woodhog17
My LRS was a very tight fit. I thought it was because I have an aftermarket fairing (Dragonfly). Took quite a bit of maneuvering and a few choice expletives but I finally got it to fit. Got the 2 outside bolts in, then pushed the center down and installed the middle bolt.
Old Jan 19, 2011 | 11:45 PM
  #34
houstonhdguy's Avatar
houstonhdguy
I've had to pull the top edge of the fairing to put on both a Cleaview and LRS. Both were snug and it took a little pressure to get to fit, but no major issue. More of a bind on the center bolt than the other two, so that's what I use to get it set then the outer ones.
Old Jan 20, 2011 | 12:35 AM
  #35
09ultraclassicrider's Avatar
09ultraclassicrider
I have 2 LRS for my scoot and they both fit just fine. I am pleased with both of them.
Old Jan 20, 2011 | 01:14 AM
  #36
Navy UC Rider's Avatar
Navy UC Rider
I have 2 Ultra Flips. They do fit snug. I flex the shield to line up the holes.
Old Jan 20, 2011 | 11:42 AM
  #37
FLUltrarider's Avatar
FLUltrarider
Personally I don't feel like I should have to drill on a part that is SUPPOSED to fit.
I agree. I could see some minor "relief" cutting, but an 1/8" on each side is more than tolerance build-up. Good luck with it, but it sounds like a tooling issue to me in manufacturing.
roadhog63@gmail.com
Jun 18, 2018 03:26 PM
Gunnysgt
Sep 17, 2013 07:22 PM
schwangster
EVO
Jul 14, 2013 03:29 AM
schwangster
Jun 10, 2009 12:35 PM
Lucky 02
Oct 24, 2006 06:41 PM
