I am currently running a EIII bias on the front and a Pirelli Night Dragon on the rear which i think is a Radial and have seen no adverse effect yet.
The Night Dragon is not a radial, shoots the he!! out of that theory.
I tried finding if the tire i am running is a Bias or radial but can't which to me doesn't make a difference anyway...I won't buy them again because they don't las long enough...EIII, 402's and Michelin Commanders for me.
i think i get it the mu90b16 replaces the mu85b16 ...right?
The MU85 is the correct size for the rear wheel of your bike. An MU90 is an alternative similar size offered by some tyre brands, but gives a slightly larger rolling diameter than the MU85. The correct tyre for the front is an MT90. Earlier models (like my 1990 Glide) also used an MT90 rear.
The Recommended sizes in your table will be fine. The MU tyre has a better load range than an MT, which is why it was fitted to later bikes like yours (and I use one on mine).
If you can get one an MU150/80 may fit your bike, be a little wider and have the correct rolling diameter. I have one on mine! It is the widest we can fit to a 3" rim.
Reason: Expanded.
