Load Equalizers re-visited
Old Jan 24, 2011 | 03:43 PM
AF Chief's Avatar
AF Chief
Question Load Equalizers re-visited
My previous post rendered a lot of information regarding load equalizers. It appears I might have been smarter to go with Custom Dynamics or HD. Since I have the Badlands 4859 already I questioned the support people at Badlands. Received an email today. I was informed by many of you that I only needed one LE, even though I was doing front and rear plus my tour-pak. Badlands told me I needed on LE for each set of turn signals. The tour-pak is included with the rear LEDs. Is the front and rear turn signals considered two sets or one? Or, are the left and right side considered two sets? I may need to trash the 4859 and go with another supplier.
Old Jan 24, 2011 | 04:26 PM
DesertH-D's Avatar
DesertH-D
Dude, you need to re-visit AGAIN! 4859 is a KURYAKYN part number, and their junk does indeed require TWO LE's... BADLANDS does NOT require two LEs! I have their ILLUMINATOR and one covers the whole bike. I recommend getting the REAL badlands at www.badlandsmotorcycleproducts.com
Old Jan 24, 2011 | 04:27 PM
fabrik8r's Avatar
fabrik8r
I'm not an electronics guy, but from my research you basically got two ways to do this LED conversion. One load equalizer (resistor) for each circuit, which generally gets very hot, or an in-line all-in-one digital module that feeds the ECM a modified signal, the latter typically doesn’t get hot and comes in various configurations of desired lighting options. If your signals are paired as a set, I'm going out on a limb and say left pair and right pair, not front and back. You should probably call Badlands back for your specific question, they would be better suited to give you the right answer.
Old Jan 24, 2011 | 04:34 PM
martinbastin's Avatar
martinbastin
So I have replaced my stock halogen blinkers(front and back) and taillight with led's. So your saying I only need the illuminator? If this is true about the illuminator(only need one LE), this one illuminator will make my blinkers(front and back) be running lights as well as my "back" led blinkers to be running lights/brake lights as well as keeping them as blinkers also. Is this confusing or do I need to describe it better?
Old Jan 24, 2011 | 04:50 PM
fabrik8r's Avatar
fabrik8r
Yes, the Illuminator is an all-in-one module that will allow you to run all LEDs. You only need one Illuminator.
Old Jan 24, 2011 | 04:54 PM
cruise_carter's Avatar
cruise_carter
https://www.hdforums.com/forum/touri...tz-lights.html
this explains what I did, one equalizer from Badlands solved all issues. would work for what you want to do.
Get in touch with Dan at Badlands and he will be most helpful.
Old Jan 24, 2011 | 05:43 PM
Sam2010's Avatar
Sam2010
only need one. You can do it LOL
Old Jan 25, 2011 | 12:15 AM
captainjack's Avatar
captainjack
one badlands equalizer for whole bike
RollinLowDeluxe
Apr 12, 2016 10:43 PM
TexFF
Nov 15, 2014 11:20 PM
Johnnypbravo
May 26, 2013 06:32 PM
klf33
Dec 12, 2011 09:03 AM
JR-Boston
May 12, 2010 06:37 AM
