Primary oil level
Old Jan 29, 2011 | 10:47 AM
JONNIEROCK's Avatar
JONNIEROCK
Default Primary oil level
How many of you with the late model bikes, the ones that require 38 ozs. of primary fluid, just dump in a quart and call it a day, and how many make sure they put in the full 38 ozs. Does it really make a difference.
Thanks in advance Jonnierock
Old Jan 29, 2011 | 10:51 AM
bagman1's Avatar
bagman1
Over filling will cause the clutch to drag and create more drag (parasitic load) on the primary chain I roughly use the markings on the bottles and call that a day or measure 2-3/4" from center of adjustment bolt to fluid level.
Old Jan 29, 2011 | 11:19 AM
'05Train's Avatar
'05Train
Yes, it really makes a difference. 38oz is what you should be using.
Old Jan 29, 2011 | 11:24 AM
Mike T's Avatar
Mike T
The primary fluid will turn darker quicker if you don't put 38oz. in it.
Old Jan 29, 2011 | 11:38 AM
Dionicio's Avatar
Dionicio
I always refill with 38oz. If You have the cover off for work on the clutch. compensator etc, Refill with 45oz.
Old Jan 29, 2011 | 11:46 AM
Faast Ed's Avatar
Faast Ed
Absolutely agree!
Old Jan 29, 2011 | 11:47 AM
Cornhusker's Avatar
Cornhusker
38 ounces like the book sez.
Old Jan 29, 2011 | 01:10 PM
dawg's Avatar
dawg
I check to see that it covers the bottom edge of the basket
Old Jan 29, 2011 | 04:30 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Yep, that's the correct way. It's the way I do it anyway....
Why would you add 45oz if you had the primary cover off??
If it comes to the bottom edge of the basket, it's full.
Do you think 7oz stays in the primary area when you drain the old stuff? A little may but I don't think 7oz does. Just my 2 cents on the matter.....
Old Jan 29, 2011 | 05:03 PM
Faast Ed's Avatar
Faast Ed
You'd be surprised how much stays. 7 oz isn't much. There are a whole bunch of clutch plates in there and every one of them coated with oil.
If the cover was off and the plates were pulled out or replaced, or had a long time to drip dry, it will take near that 45 oz to reach your visual checkpoint.
My visual check point is the clutch spring. I like to see the bottom edge of it barely submerged.
