Back from the 'stan
Old Jan 30, 2011 | 10:58 AM
HawkPilot's Avatar
HawkPilot
Default Back from the 'stan
Ladies and Gentlemen,
I recently redeployed from Afghanistan and got my bike ('06 RKC) out of storage. It was started and ridden every now and again and was on a battery tender when not being ridden, but hasn't been regularly ridden since Dec '08. Aside from changing the oil is there anything else, specifically, I should inspect to ensure it's mechanically sound and ready for some rides for the upcoming season?
V/r,
Rich
Old Jan 30, 2011 | 11:04 AM
ChristoHD's Avatar
ChristoHD
Thumbs up
Glad you are back and able to ride, and that you for your service to our country! :-)
Check your tires - air pressure and for cracks for sitting so long.
Oil change like you said, and you should be really good to go.
V/r,
Rich
Old Jan 30, 2011 | 11:20 AM
Old Bones's Avatar
Old Bones
Change all fluids, check, even better change tires. make sure the loose nut on the handle bars doesn't get looser. Thank you for your service and welcome home.
Old Jan 30, 2011 | 11:25 AM
SpiderPig's Avatar
SpiderPig
Again, THANK YOU for your service! Pull the fluids out and put in fresh and you should be good to go. After checking the air pressure, might want to make sure lights and brake switches are all in working order as well. Let it warm up to the point of the rocker boxes are getting warm before riding. If the bike is running good then the fuel might be able to be run if there was stabilizer dumped in during storage. If not drain fuel and replace with fresh.
Old Jan 30, 2011 | 11:27 AM
Dionicio's Avatar
Dionicio
Do as the others have said. Welcome Home and Thank You for Your service..........RIDE SAFE!
Old Jan 30, 2011 | 11:32 AM
DTTJGlide's Avatar
DTTJGlide
Thanks for your service. Check the tires & get on & ride it, the oil should have been changed before you stored it to get rid of the acids in it, & hopefully when it was ridden while you were gone they rode it long enough to get it fully warmed up. The best way to store for extended periods is to change all fluids prior to storage. Thanks again & have a great ride.
Old Jan 30, 2011 | 11:48 AM
Bait56's Avatar
Bait56
Welcome back. Thank you for your service.
Old Jan 30, 2011 | 12:29 PM
krazy3's Avatar
krazy3
I can't say THANK YOU enough.
RIDE SAFE!!
Old Jan 30, 2011 | 01:08 PM
skratch's Avatar
skratch
wow, welcome home. sure hope you didn't spend that whole 2 years over there! from this retired sm, thanks for your service.
one suggestion that you haven't got (and they've all been good, btw) is to ride that bike down to your local hd and put it and some of that deployment money on to a se bike.. you deserve it!
Old Jan 30, 2011 | 01:16 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
air shocks like to leak down .
