Limp mode again!
Old Feb 20, 2011 | 01:06 PM
Toe Knee's Avatar
Toe Knee
I haven't heard of any bikes even having this issue other then the 2008 bikes. most of the issues where due to the ECM connector. my 2008 had the problem. bent pins. it happened during my 2 day of ownership. they connector pins where "repaired" and i went on to put 16k miles on that bike with out the problem happening again.
You have to take care when removing or installing that connector.
btw-I got my 2010 in august. I had 3 solid weeks of rain before the end of fall and managed to 6k miles on the bike with NO issues.
Old Feb 20, 2011 | 01:18 PM
mkguitar's Avatar
mkguitar
- Oh- you have a power commander installed???- I didn't see that at the start of this thread-
That's a complete other issue.
as suggested earlier, connector pins could be bent or loosened, and that may have happened to your bike.
bypass the power commander, do a check of all the pins, look for any bent pins.
I'd pull the PC before trying to get any "warranty" service- they have no obligation with the PC on there.
It has been suggested over and over that piggybacked devices on the ECM can cause bad sensor readings and interfere with actuators. It has also been suggested that the PC can go bad.
mike
Old Feb 20, 2011 | 01:21 PM
klaybus's Avatar
klaybus
Do a search, there are many people that have had the issue with the TBW.
Old Feb 20, 2011 | 01:22 PM
klaybus's Avatar
klaybus
mike
They installed the PC when they installed the SE A\C & did the dyno-tune.
Old Feb 20, 2011 | 01:25 PM
Roadie09's Avatar
Roadie09
If you have the PC-V installed, make sure the contacts on the plugs (both ecm and PC-V) are very clean. Coat the plugs with die-electric grease and put it back together. I had a corroded terminal and it was jacking up the cruise control.
I have 40K on my '09 and the same TBW unit has been on the stock bars and internally wired on two other bars and it has not given me any trouble (hope it stays that way).
It may not be H-D's fault the bike keeps going into limp mode.
Old Feb 20, 2011 | 01:31 PM
klaybus's Avatar
klaybus
FWIW, the last time it went into limp mode it was bone stock with 500 miles on it.....
Old Feb 20, 2011 | 01:35 PM
Toe Knee's Avatar
Toe Knee
p0134=o2 sensor front
p0154=Rear O2 sensor open/not responding/high
p1511=throttle actuator control power management code.
p2101=TAC motor circuit range/performance (actuation error)
P0031=?
Check the pins on the connector.
2008 there was a fairly widespread problem. 2011's there isn't.
edit=when I say check the pins, you need to carefully check the ECM's, the wire harness's AND the power commander's.
Old Feb 20, 2011 | 01:40 PM
Toe Knee's Avatar
Toe Knee
btw-a kid was fired from the dealership that I bought my 2008 at. Reason=the ecm connector issue was a problem at the time and another customer went down because of it. the dealership took blame for it because it's their policy to specifically check that connection on every bike that leaves their place.
When mine had the same issue they found out the same kid over looked mine during set up. again, it's part of prep for them to specifically check that connection.
Old Feb 20, 2011 | 01:48 PM
klaybus's Avatar
klaybus
Thanks for the code list. I'll go check the PC-V connection.
Old Feb 20, 2011 | 02:10 PM
klaybus's Avatar
klaybus
Hmmm. Hoping the dealer knows what to make of these. 0134 & 0154 I know are due to the PC-V. The others IDK.
DTC: P0031
FAULT CONDITION: O2 heater low/open
PRIORITY ORDER: 82
SOLUTION: 6.7 DTC P0031,P0032,P0131,P0132,P0134,P0151,P0152,P0154
DTC: P2101
FAULT CONDITION: Throttle actuator control motor circuit - range error
PRIORITY ORDER: 47
SOLUTION: 6.27 DTC P2100,P2101,P2102,P2103
DTC: P1511
FAULT CONDITION: Throttle actuator limited power management mode
PRIORITY ORDER: 91
SOLUTION: 6.23 DTC P1510,P1511,P1512
DTC: P0134
FAULT CONDITION: Front O2 sensor open/not responding
PRIORITY ORDER: 88
DTC: P0154
FAULT CONDITION: Rear O2 sensor open/not responding
PRIORITY ORDER: 89
