Intercom Headset setup ???'s
Old Feb 22, 2011 | 03:27 PM
prostar's Avatar
prostar
Default Intercom Headset setup ???'s
On my 09 Ultra I am having an issue. My wife has a half helmet with the IMC HS - H170 headset. My bike has the current download of software for the radio. For her to talk to me she has to almost yell before the VOX is activated. I have the VOX set up 1 notch under OPEN. Is there a separate VOX setting for the passenger that I am not finding? I have a msg into IMC and they are trying to get me an answer.
Old Feb 22, 2011 | 03:34 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
dude, where else can you spend 5 hours, with your wife, with her legs wrapped around you....and you don't have to talk to her? tell her you can't make it work, and enjoy the peace!!
Old Feb 22, 2011 | 03:36 PM
vtwinbob's Avatar
vtwinbob
not real sure in this but, has she tried the switch on her right side?? it's the PTT/VOL/ could be it
Old Feb 22, 2011 | 03:39 PM
prostar's Avatar
prostar
Point Taken
Old Feb 22, 2011 | 03:53 PM
Wassup8687's Avatar
Wassup8687
I believe there is a control for both the rider and passenger. Haven't been on the bike in awhile though because of the snow. Did you check you manual?
Old Feb 22, 2011 | 04:03 PM
prostar's Avatar
prostar
wassup there is headset volume front and rear but appears to be one vox setting for both mic's. I am going to test tonight using the passenger PTT in intercom mode to see if volume is any better. I have been all over the manual but was hoping someone had one of those little known facts that makes these work better.
Old Feb 22, 2011 | 05:27 PM
Linville Lion's Avatar
Linville Lion
We close down the VOX and use the PTT.
Old Feb 22, 2011 | 06:55 PM
prostar's Avatar
prostar
further testing is the IMC headset doesn't work on VOX but works on PTT, I pluged it in both ports, rider and passenger and had same results. Appears that I have everything on radio correct and problem is with headset. Tomarrow I will call back to IMC to see what they will do. I know I could use intercom on PTT but if communicating with other bikes on CB they hear conversation
Old Feb 22, 2011 | 07:02 PM
eazyduzzit's Avatar
eazyduzzit
I have the exact same problem on my '08. The IMC headsets worked fine on my Royal Star, but I can only get it to work in PTT mode on the Ultra.
Retired Guy
Nov 23, 2013 07:57 PM
Garmon1966
Oct 1, 2013 06:59 AM
davessworks
Aug 31, 2012 09:17 PM
bill1nat
Oct 3, 2010 10:28 AM
Gumby256
Jun 27, 2010 01:10 AM
