Looking for a source and part # to buy packs of 10-? drain plug o-rings for an 2010 Ultra Limited. The same o-ring fits the engine, primary and transmission.
O rings are strange things! I have spent more time than I care to think over the years looking for alternatives. Unless you know the exact size and type it is cheaper and simpler to get the correct ones from a local dealer.
If you have the means to accurately measure your O-ring, or the groove it fits into, you can match it up at McMaster Carr industrial supply online. They also have material reference guides to make sure you get the right "petroleum compatible" rubber compound.
