I have an 02 Ultra Classic where the seat is attached under the tour pak through the rear fender with a phillips screw. I have a 12" screwdriver to remove it. The problem is you can't go at it straight-up but at an angle which is taking its toll on the screw head. Has anyone with this problem found a better way?
I had the HD thumbscrew that KCFLHTC showed a picture of on my bike when I purchased it! I constantly switch back and forth between seats depending on if I have a passenger or not and this makes it EXTREMELY handy! The only down side is if you loose the little plastic washer, be prepared to lose the thumbscrew, it will vibrate loose!
