Engine Went Dead
Old Mar 14, 2011 | 01:16 AM
roadgliderick's Avatar
roadgliderick
dont make any turns
Old Mar 14, 2011 | 06:59 AM
cochon's Avatar
cochon
Originally Posted by tpmurray
Certain year bikes had Maxi Fuses would cause this. I can't remember what years were affected but the fix, if I remember right, was a higher amp main fuse.
Also, if your bike is FI check for leaking fuel lines inside the tank.
I had the main circuit breaker problem also. When it would trip out, everything on the bike went dead, no lights, no horn, no radio, no instruments. This doesn't sound like the problem that you described.
Old Mar 14, 2011 | 08:16 AM
iclick's Avatar
iclick
I would also tend to blame the IAC motor. If the engine was at idle speed at the time, look for threads on idle problems and you'll find quite a few relating to '07 bikes. I think your '06 uses the same IAC motor, and that may be the problem. Try cleaning the idle orifice with carb cleaner and if that doesn't work I would just replace the motor (~$40).
Old Mar 14, 2011 | 08:45 AM
Biker Oma's Avatar
Biker Oma
Hubby had the engine quit on us too. We were riding 2up, at highway speed and then....... nothing. He was startled, but coasted to an upright stop, without going onto the gravel shoulder. He was able to restart it. The dealer couldn't find a problem, but it happened again and finally we concluded the kill was caused by the high beams and cruise being on at the same time: the fuse was undersized.
Old Mar 14, 2011 | 10:03 AM
mcman's Avatar
mcman
Wow, never thought I'd get this many responses. Thanks. If and when it does it again or when I find out what the problem is, I'll post the solution. Hoping it just won't do it again. Where this happened really presented no dangerous hazard. If my wife had been in the back and we had been riding on a 4 or 5 lane interstate in 5 o'clock traffic, the outcome might have very well been different. Rather a scary thought.
Dirty_diesel
Jun 18, 2019 08:15 PM
kareengas
Feb 4, 2016 08:59 PM
1911guy
Electrical/Lighting/Alarm
14
May 27, 2015 10:45 AM
Lucero1
Feb 27, 2012 11:40 AM
gregorysfd
Mar 13, 2008 08:33 PM
