Installing SE compensator kit w/pics
Old Jul 30, 2011 | 05:42 PM
  #191
cruzmisl's Avatar
cruzmisl
Awesome thanks a ton for the replies. One last thing. What bolts in this install require loctite, if any?
Old Jul 30, 2011 | 06:27 PM
  #192
bowa18's Avatar
bowa18
None, the new compensator bolt comes with loctite already in place.
Old Jul 30, 2011 | 07:03 PM
  #193
speakerfritz's Avatar
speakerfritz
I'm replacing my SE compensator soon. While in there, going to install a new clutch basket and a new starter. I have all the parts already. Since Im pulling almost everything out, do you folks think I still need to do the grinding gig. Harley didn;t have to do any grinding to get it in there and I don't think dealerships are grinding vs charging the service plan the 98 bucks an hour to pull out what ever needs to be pulled out.
Old Jul 30, 2011 | 07:20 PM
  #194
HDThunder's Avatar
HDThunder
If you're pulling everything out already including the clutch and starter it's only another five minutes to pull the inner primary. If you do that you don't need to grind. Might as well pull it since you're going that far. At that point you'll need to decide if you need to replace any one or or all of these: inner primary gasket, transmission shaft seal and the seals on the inner primary bolts. Only downside is if you ever need to pull the compensator again you're in the same situation... to grind or pull everything apart.
Old Jul 30, 2011 | 08:57 PM
  #195
speakerfritz
ok, makes sense....thanks
Old Jul 31, 2011 | 11:00 AM
  #196
cruzmisl's Avatar
cruzmisl
I just put mine back together and filled the primary with Redline MTL so we'll see how that works out.
Anyway, what a huge difference. As soon as I started the bike I knew it was different. No explosion on startup-the starter bang is gone! I took it for a ride and the low speed "bag of bolts" sound is gone too. I just took it for a short ride but so far I love it.
I ended up grinding away a little more in order to get the SE part on but it wasn't too much.
Thanks for the tutorial. I agree with the others its an easy job.
Old Aug 20, 2011 | 03:36 PM
  #197
Steel Wheels's Avatar
Steel Wheels
2010 FLHRC, 9k mi.
Have been getting some pronounced, intermittent bang/knocks from primary. Dealer went in & found nothing wrong, so I paid for the comp & installed today.
No big deal to do, took 1 1/2 hours. The chain is submerged in oil at the point where the grinding took place as is the clutch basket, so I see no problem with removing the material.
I'll update on the noise after a week or so - by then it will have done it or not.
If the noise is gone I'm going to see about reimbursement for expenses.
Old Aug 20, 2011 | 04:17 PM
  #198
davessworks's Avatar
davessworks
Not so. Yes the compensator bolt comes with Loctite in place but the question was what needs to be Loctite'd for the whole job. You need to reapply Loctite to the Inner Primary bolts (if you loosen them) as well as the outer primary bolts. If you go strictly by the book you are actually supposed to replace the inner primary bolts - but I know nobody that does so.
You also are supposed to loctite the clutch bolt (the one that holds the clutch to the transmission shaft). Again - if you remove it.
Finally - although nobody says you have to - it doesn't hurt to put Loctite on the chain tensioner bolts.
Make sure you use the correct Loctite for each application.
Old Aug 20, 2011 | 11:24 PM
  #199
bowa18's Avatar
bowa18
I believe he was referring to what needs to be loctite'd when doing the "grind" method (which is what is being discussed in this particular thread).... so the inner primary bolts aren't being touched nor is the clutch bolt, that's why I answered in the way I did. As far as the outer primary bolts, no need to loctite them in my opinion and I'm pretty sure nothing is mentioned in the service manual about using loctite on them either but I'm not 100% on that. I agree if you go to the trouble of removing parts that aren't necessary to do the swap then you do need to apply loctite on all the bolts that require it. No sense confusing guys with another method of doing the job (that would be better served in another thread showing the other method and all that's required to complete the job in that fashion). With the grind method outlined in this write up nothing needs loctite as the new comp bolt has it in place already. I realize you're not fond of the "grind" method but that is what this particular thread is about.
The reason I posted the tutorial in the first place was to show how simple it was to for a do-it-yourselfer to tackle this project. I didn't invent this method, I merely took the time to do a detailed write up to hopefully help some guys that were on the fence about doing it themselves understand that it's do-able at home. Some guys are intimidated by removing the clutch, inner primary, etc. etc. (I do agree it's not that complicated to do) so this method simplifies the comp. swap with a minimal amount of parts being R&I'd. I work on cars for a living and know my way around bikes as well.... I'd do the grind method vs. "by the book" method every time. Why remove more parts than needed. Smoothing out a little rib/ridge on the case won't effect anything, I'm 100% sure about that. There's always more than one way to skin a cat, in this thread we're grinding the skin off Thanks, Larry
Old Aug 21, 2011 | 02:09 AM
  #200
davessworks
Surely you jest. Look - I don't care whether you grind or not. Your write up is very nice and I'm sure plenty of people have done the job this way. Personally I really appreciate it when someone goes to the trouble to document how to do a job like this. Furthermore I'm all for saving time and money. Personally I don't believe it's necessary to change the outer primary cover gasket for instance and have done this job several times each time reusing it and saving about $36 per.
I'm posting here to correct a clear mis-statement on your part in responding to the post:
and again:
The manual is very clear about this and for good reason. The bolts can and will come loose.
Screw this up and your primary may well develop a serious leak.
Specifically the manual states:
Apply a drop of Loctite Threadlocker 243 (blue) (Part no. 9964297). Install nine short (1) and four (2) primary cover fasteners in positions shown. Snug fasteners.
It then goes on to show a torque sequence.
On another note, look, it's a nice thread and I applaud you for starting it - but do you really need to police it too?
If you care that much about where I post perhaps you should get a job as a moderator.
