I changed my compensator last night to the SE compensator. Went pretty well, however I wasn't as neat with the rags and towels around the rotor as I would have liked. Ended up removing the stator to make sure I cleaned out all the aluminum bits, wasn't a big deal though.
I started out using a carbide deburring bit in a high speed die grinder but it clogged up with material quick. Went to the hardware store and found a Wolfcraft conical rotary rasp, says for use on wood, it worked great on the aluminum. Only cost about $3.50 and worked great in a drill.
I didn't get much time to ride but I can say hot starts are better, and shifting is less of a clunk/bang, especially neutral to 1st and 2nd to 1st.
Thanks for the how-to bowa18.
Yeah, when I did mine the deburring bit clogged as well. I used a drum sander bit with a 60 grit drum in my dremel tool. It worked the aluminum off much faster and easier to control.
You're welcome! Glad to hear you did it yourself. I'm extremely happy with the SE compensator.... I've got to put a few thousand miles on it so far and the bike really feels so much better at slow, creeping along speeds where you have to feather the clutch a bit. No more shudder. Only wish HD would have put it in to start with, oh well I'm glad I did it.
You hit the nail on the head. If HD knows this is an issue, shame on them. Are the new bikes like this also?
Nope, the 2011's come with the SE comps already installed! Us lucky bastards with '07-'10's get to buy them ourselves! Although some owners have gotten them replaced under warranty, others are told that it's "normal" and get to pay for the swap. Unfortunately mine was "normal" so I got to buy my own.
For those that got the dealer to do the replacement under warrantee, what did you have to tell them? I am planning on talking to my dealer soon about the SE upgrade but want to make sure my wording is right to get it under warrantee.
I installed the SE Compensator last night. I removed the whole inner case and the clutch assembly. It's not that big of a deal. An extra 15 minutes. I have heard from other mechanics that you should not shave the primary case to get the old rotor out. That burm is in the case for a reason. They tell me that it is there to pool the oil so the chain will pick it up better. Not sure I agree with that but would probably add a few more onces of oil to the primary. I also had a HD Rep from the main office tell me that indeed the older Compensators 2007-2010, were week. The SE compensator is surely the way to go.
Well thanks to bowa18s fine write up and pictures I did the compensator change to my "07" Ultra last week. I had not really had a problem except for a weird "click" every once and a while. Like a lot of others everything looked great (only 6,000 miles). Although I have a jack, I decided to pull the shifter, floorboards and primary cover using my Lean Right. After removing these items I decided to do the entire job on the Lean Right, I believe that this made it easier than it would have been on my MC Jack. I let the primary drain over night on the jiffy stand and removed the cover the next morning on the Lean Right, I had NO fluid spill when I removed the cover. I also went to the next heavier clutch spring while I had the primary open ( Just slightly heavier pull ) for a little added insurance when riding two up. The primary fluid had not been changed yet so I knew that the refill was 45 ounces, but decided to measure how much came out. I was surprised that I got about 48 ounces. That tells me that they must have put about 49-50 ounces in at the factory. I am very happy with the clutch spring and compensator,no more weird noises and the clutch engagement feels a little more positive.
