TBW Question
Old Mar 28, 2011 | 05:47 PM
tj316's Avatar
tj316
Default TBW Question
I am putting my bike back together after being painted, while apart I installed the Yaffe Monkey bars and ran the wires internally,I've plugged everything back and just installed the inner fairing, if I turn the ignition switch to on and turn the throttle should my trap on the EFI system be working ? I turned the bike on (I can't crank it the tank is not on yet) and turn the throttle and don't hearing anything moving , is this normal ? Trying to double check before putting the fairing back on THANKS
Old Mar 28, 2011 | 07:41 PM
bagger76's Avatar
bagger76
Yes, I did the same thing.The valve doesnt move by turning the throttle and key on. I think it needs to see crank sensor and rpm first as input
Old Mar 28, 2011 | 08:32 PM
tj316's Avatar
tj316
cool thanks
Old Mar 28, 2011 | 08:39 PM
triple buzz's Avatar
triple buzz
bagger 76 is correct. I had the same concern when I did mine.
Old Mar 28, 2011 | 09:36 PM
Phat09flhx's Avatar
Phat09flhx
Guess I took the cross my fingers approach, I started it up and twisted the throttle and yes I had everything back together properly.
trackadaptor
Apr 9, 2021 08:46 AM
Scottzp
Apr 26, 2014 02:20 PM
Casper
Jul 24, 2012 11:37 PM
mikecourthd
Mar 16, 2011 09:51 PM
ICEMAN-WB
May 7, 2008 09:39 PM
