Cam options and opinions
Old Mar 30, 2011 | 10:01 AM
superstandardFL's Avatar
superstandardFL
6th Gear
Default Cam options and opinions
ok guys i am running a 2007 FLHT 103 cubic inch, SE255 cams, set of heads, with bigger valves, full true dual rinehardt exhaust SE air cleaner and power commander i am wondering what a set of .575 cams would do for me? what would be biggest differences? positves? negatives? also should i go with a 50 mm throttle body as well let me know what u guys think thanks in advance
Old Mar 30, 2011 | 03:30 PM
PMG52's Avatar
PMG52
who did your heads? you could look into woods, he has a nice selection and ive had good luck with them. you just want to make sure everything complements one another. you are gonna want a cam thats happy with your compression. and i would just have your stock throttle body re-worked, check out hillside, they could hook you up with this.
Old Mar 31, 2011 | 07:39 AM
superstandardFL
6th Gear
my heads were done by a guy in Eastern Canada here by the name of Dave Lind he does a lot fo work on drag bikes etc and his work is known pretty well here in my area my stock intake was matched and polished to the heads when he did them so maybe thats all i require
Old Mar 31, 2011 | 07:50 AM
PMG52's Avatar
PMG52
yea sounds like your set there then. i would possibly try a woods tw7h or a tw6h. the 6h is a .590 lift cam, but it seems to work well on my fathers roadking. hes making 106hp and 103tq on a 95 build. lots a torque down low
Old Mar 31, 2011 | 08:22 AM
imrotton2's Avatar
imrotton2
im running s&s 570 gear drive. and my tq is running around 120 ft lbs on my 103" with stock throttle body
Old Mar 31, 2011 | 08:50 AM
cmcsns's Avatar
cmcsns
From: Beverly Hills, Fl. Swimmin pools. Movie stars
I'm running Wood's tw7h, makes plenty of usable power
Old Mar 31, 2011 | 10:24 AM
Mike's Avatar
Mike
Woods TW5-6 or Cyclerama 575 both seem to work well on the 103 motors. Doubt the larger throttle body would make much difference unless you have the heads ported.
Dwaters
Engine Mechanical Topics
Nov 16, 2017 09:06 AM
blksoftail
Exhaust System Topics
Jul 15, 2011 11:30 AM
kwag245
Oct 31, 2010 07:03 PM
mdelbello
Nov 8, 2007 10:35 AM
tarheelrdr
Apr 28, 2007 10:21 PM
