Cylinder Cooling Fin Corrosion
Old Apr 5, 2011 | 02:00 PM
spokes54's Avatar
spokes54
Default Cylinder Cooling Fin Corrosion
My 06 SG is showing corrosion on the left side of the front cylinder fins, and only on the polished ends. Any tips, tricks, ideas as to how to get it removed?
Thanks
Old Apr 5, 2011 | 02:03 PM
DocHarley's Avatar
DocHarley
Nevr-Dull works great for me, I've have also used fine steel wool and WD40.
To prevent corrosion I wipe down my fins now and then using a rag and WD40.
Old Apr 5, 2011 | 02:13 PM
spokes54's Avatar
spokes54
i was afraid to use steel wool but I'll give it a try. The roads in CT are really beat this year from the brutal winter we had. Add to that the left over salt and it's a wonder everything doesn't corrode. Thanks for the tip.
Old Apr 6, 2011 | 01:32 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
When aluminum starts to corrode, you need to remove the corroded areas and polish to a smooth surface. Try a grade 600 sand paper on a wooden block and you impregnate the abrasive with mineral oil or pork fat to avoid scratches.
Old Apr 6, 2011 | 06:57 AM
spokes54's Avatar
spokes54
thank you expat. I'll give it a try.
Old Apr 6, 2011 | 07:01 AM
FDHOG's Avatar
FDHOG
I used to use Brass Wool on my boat hardware. It won't scratch.
Light coat of WD40. I get the same thing cause I forget to coat them before winter.
Old Apr 6, 2011 | 08:52 AM
jamesroadking's Avatar
jamesroadking
I would touch up the black paint with high temp BBQ grill paint. Then would
use green scotch bite pads wetted with WD-40 on the edge of the fins on
my '99 Roadking that was a daily ride.
Old Apr 6, 2011 | 09:42 AM
VINNIE JAMES's Avatar
VINNIE JAMES
i have the same problem. will try some wd40
Old Apr 7, 2011 | 08:00 AM
Expat1's Avatar
Expat1
Black mat paint has to be as thin as possible otherwise it will not diffuse enough heat. The worry about using scotch brite is that it will make the edges of your fins look different / rounded compared to the rest of the machined surfaces of your engine. WD-40 may be a bit thin for the job because the oil / fat is used to avoid loose aluminum particles from grooving into the surface being polished / repaired.
Old Apr 7, 2011 | 10:18 AM
CigarCritic's Avatar
CigarCritic
I like this idea.
Indy Road Dog
Engine Mechanical Topics
16
Aug 1, 2021 05:48 PM
Stopit
Jun 15, 2014 12:02 AM
cruzmisl
Detailing
Nov 1, 2011 02:13 PM
TexasRog
Detailing
Dec 27, 2010 07:21 PM
Big Bear
Feb 23, 2008 04:15 PM
