Question about Pinging
Old Apr 18, 2011 | 11:07 AM
VTwinJaxFL's Avatar
VTwinJaxFL
Default Question about Pinging
I have a 2005 Road King, 95 cu with 10.5 to 1 compression, Mikuni HSR 42 carb and cams. I bought the bike used with the work already completed. I am not sure what type of cam is in the bike. I had the bike dyno checked at Bike Week, they said it looked like the AFR was good or close enough to not want to tune it. I think they dyno guys were more into just doing Power Commanders. The bike pulled in 4th gear a 92 hp and 90 tq. I have a Daytona Twin Tec ignition installed set to the recommended settings by Daytona Twin Tec.
The issue I have is that in 5th or 6th gear, if I am just cruising along at a low RPM, if I want to get on it, it will ping a first. If I down shift it will be fine and no ping. I am not really lugging the engine, these motors should be able to accelerate without down shifting at say 60 in 5th gear. Does this sound like maybe I have the wrong cam for my riding style or a lean condition or timing issue? I am looking around for ane experienced dyon tuner in Jax FL, but they usually just do a WOT tune and I need a tune for the way I ride. Any advice?
Old Apr 18, 2011 | 11:19 AM
chevele72's Avatar
chevele72
You need to talk to Doc just 1 1/2 hr or so SW of you in Minneola. Worth the ride.
http://www.docsperformancetuning.com/
Old Apr 18, 2011 | 11:23 AM
eja's Avatar
eja
Sounds like u r slighty lean. Try adding a little fuel.
Old Apr 18, 2011 | 11:25 AM
Rat1's Avatar
Rat1
I would say the added compression and possibly timing adjustment, is causing your ping. You have two options, get it downtuned slightly or downshift out of 5th for passing.
Well there is a third option, start riding were you can get 100 oct fuel all the time.
Old Apr 18, 2011 | 12:13 PM
TWIN CAM 96's Avatar
TWIN CAM 96
On warm days my SG does the same thing or if I go up to the mountians if so I'll mix in about 2oz. of Lucas Octane Booster and it runs real good with that. You might not be getting the octane rating at the pump.
Old Apr 18, 2011 | 12:15 PM
VTwinJaxFL's Avatar
VTwinJaxFL
I have thought about that, it is about 2.5 hours away, still not too far.
Old Apr 18, 2011 | 12:20 PM
SleeplessinVegas's Avatar
SleeplessinVegas
How many miles on the fuel filters? I have been told to change them out at 25,000 miles as they get plugged up and can cause a lean condition.
Old Apr 18, 2011 | 01:05 PM
VTwinJaxFL's Avatar
VTwinJaxFL
Bike has 15,000 miles, so that or less.
jlasoftail
Exhaust System Topics
26
Oct 28, 2012 11:35 PM
Buckinfitch
Apr 29, 2012 08:44 AM
Duke of HD
Jul 15, 2009 03:28 PM
BadPiggy
Nov 2, 2008 10:49 PM
91ultra
EVO
Jul 14, 2007 05:38 PM
