Removing axle end covers
Old Apr 19, 2011 | 02:23 PM
lilricky's Avatar
lilricky
Default Removing axle end covers
The only thing standing between my newly painted front fender and getting the old one off are these factory axle caps. Does anyone know how to get them off without destroying them? Or, should I just count on ordering a new pair.
Old Apr 19, 2011 | 02:29 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Factory axle caps?
Did you look for set screws?
Old Apr 19, 2011 | 02:32 PM
Turbo Turtle's Avatar
Turbo Turtle
Not to be to discriminate here, but if you can't get them off, should you be replacing a fender?
Mine are held on with two allen screws located wherever they are when installed, which are on the bottom side on mine.
But without a picture nobody here knows what type of caps you have.
$0.02
aka Bob
Old Apr 19, 2011 | 02:43 PM
lilricky's Avatar
lilricky
$0.02
aka Bob
D'oh,
They look like this:
Thanks
Old Apr 19, 2011 | 02:45 PM
shooter5074
Originally Posted by lilricky
D'oh,
Thanks
See the set screw? Allen wrench, loosen set screw, and problem solved.
Old Apr 19, 2011 | 02:47 PM
DamifIknow's Avatar
DamifIknow
You got alot a esplainin to do
Old Apr 19, 2011 | 02:51 PM
Turbo Turtle
Hey, them look like mine! Give me back! LMAO
Oh yeah, and upon reinstalling them, the screws need to come to rest on a highpoint of the axle nut, cause their not long enough to reach the flat side of said nut. Yea another MOCO malfunction!
aka Bob
Old Apr 19, 2011 | 02:52 PM
Guntoter's Avatar
Guntoter
I have the smooth axle caps on mine and on the right side one, the tiny allen screw hole is now rounded out, so no tool works at all. But since the left will come off, where the axle nut is located and removed, I have always been able to pull the axle out, leaving the right cover in place.
Old Apr 19, 2011 | 03:15 PM
txrarebear's Avatar
txrarebear
aka Bob
On "most" of the H/D axle covers I have installed, there is a "longer" set screw that you put on the cap that fits on the nut side (usually the sloppy side!), so you can run it through and seat it on one of the wrench flats without it going all the way through and "falling in".
Note:
I am only familiar with the 06 - 11 model Softails, Dynas and Touring models though.
The short set screw fits on the opposite side cap. Most of the time that cap has a more proper fit on the round portion of the axle and the shorter set screw works on that side with no problems either.
Disclaimer:
They may not ALL be that way, but the two different styles (tapered and smooth styles) I have worked with went on that way.
Oh yeah, don't try to "wrench them down tight"....just snug them and they'll be fine.
Old Apr 19, 2011 | 03:26 PM
Primo's Avatar
Primo
Are you sure you even need to take the wheel off?
I took my stock fender off of my Street Glide and replaced it with a freshly painted Fatboy fender and did it all with the front wheel on the bike.
Unless you have some severe wraparound type fender you may not have to mess with the wheel at all.
