Head Pipe Installation
Old Apr 20, 2011 | 07:08 AM
KCFLHRC's Avatar
KCFLHRC
Default Head Pipe Installation
I'm getting ready to reinstall my CATLESS head pipe on my 11 Limited and was wondering what the proper procedure was as far as tightening the flange nuts and what the torque specs are. I don't have a service manual yet. Any help would be appreciated.
Old Apr 20, 2011 | 07:27 AM
equandt's Avatar
equandt
I just did this this past weekend. I followed the procedure in the HD service manual. From memory (someone may want to check me on this):
Tighten the lower nut on the rear flange to 9 to 12 in lbs
Tighten the top nut on the rear flange to 100 to 120 in lbs
Tighten the lower nut on the rear flange to 100 to 120 in lbs
Tighten the lower nut on the front flange to 9 to 12 in lbs
Tighten the top nut on the front flange to 100 to 120 in lbs
Tighten the lower nut on the front flange to 100 to 120 in lbs
Hope this helps. Good luck.
Old Apr 20, 2011 | 07:41 AM
RoaddogRG2011's Avatar
RoaddogRG2011
How was it getting the CAT removed?
Old Apr 20, 2011 | 09:16 AM
Northbound Southerner's Avatar
I would check the manual again. I am not at home but it seems like those torque values are really high...I could be wrong. I am a lot
Old Apr 20, 2011 | 11:22 AM
scoobs's Avatar
scoobs
Equandt has it right...just looked in my book.
Old Apr 20, 2011 | 01:02 PM
HDThunder's Avatar
HDThunder
You realize he said INCH lbs. right? That's the equivalent of about 8-10 FT/lbs. Not really that high.
Old Apr 20, 2011 | 08:51 PM
KCFLHRC's Avatar
KCFLHRC
Had a local shop cut the pipe in half. Removing all the CAT material is a pain. Then had a local welder put it back together. Took probably 3 to 4 hours to remove all the CAT and clean it all up.
Old Apr 20, 2011 | 08:56 PM
KCFLHRC's Avatar
KCFLHRC
Thanks guys, I'll tackle this over the weekend,
jmay86
General Topics/Tech Tips
Nov 17, 2015 10:34 AM
jt metal
Jun 4, 2015 06:25 AM
BlockHead96
Exhaust System Topics
Aug 10, 2014 05:50 AM
BuzzL
Jun 20, 2012 10:40 PM
MrHog
Sep 25, 2009 05:37 PM
