Street Glide Fascia
Old Apr 21, 2011 | 07:41 AM
ponch3640's Avatar
ponch3640
Default Street Glide Fascia
Ok so i have bought the street glide fascia and its at paint, and i have researched how to install the fascia and the light. Just took off my taillight assy and checked my plugs and from what i see there is no place to plug in the assy. Enclosed is pictures of the taillight assy, run/brake light, and the plug which has male connectors. Trying to hook up to a 09 FLHT.
Attached Thumbnails Street Glide Fascia-2011-04-21_08-27-42_500.jpg   Street Glide Fascia-2011-04-21_08-27-12_5471.jpg   Street Glide Fascia-2011-04-21_08-28-24_931.jpg
Old Apr 21, 2011 | 07:54 AM
utlonghorns416's Avatar
utlonghorns416
If you need a updated tail light let me know. I have one Ill sell you $65 shipped. Its off a 09
Old Apr 21, 2011 | 08:08 AM
dawg's Avatar
dawg
Do you run a tourpak with lights or any plans to? Check your tourpak harness that is tied along the left side of your bike.
Old Apr 21, 2011 | 08:17 AM
ponch3640's Avatar
ponch3640
I dont plan on running a tour pack, and is this said harness inside of the fender tied up with the rest of the wiring harness?
Thanks
Old Apr 21, 2011 | 08:21 AM
Avalanche_Mutt's Avatar
Avalanche_Mutt
updated tail light won't help you... I spliced mine in to the incoming wire harness but i have the newer tri-light you can splice the one you have in too the plate light
Old Apr 21, 2011 | 08:41 AM
Harleypingman's Avatar
Harleypingman
Thanks
The harness Dawg referred to and the one you want is the tour pak harness and it will be on the left side of the bike under the side cover or along the frame in the vicinity of the seat. Since your bike is an FLHT, it may also have the antenna cable with it. The tour pak harness will have a three wire connector that mates with the SG LED light you have. That harness is what's used on the SG for the LED light.
Carl
Old Apr 21, 2011 | 08:52 AM
ponch3640's Avatar
ponch3640
ok i am guessing that i found the tourpak harness it was behind the left side cover next to the antenna harness. Enclosed is pics of the connector and of the run light and brake light. For those of us with the 09 FLHT and any other model with the harness behind the side cover i hope that this helps.
thanks for the help harleypingman and dawg
Attached Thumbnails Street Glide Fascia-2011-04-21_09-32-17_204.jpg   Street Glide Fascia-2011-04-21_09-32-28_285.jpg   Street Glide Fascia-2011-04-21_09-32-40_94.jpg   Street Glide Fascia-2011-04-21_09-32-56_520.jpg
Old Apr 21, 2011 | 08:21 PM
utlonghorns416
Your right, my bad.
Old Mar 15, 2012 | 10:16 AM
Buzzmyster's Avatar
Buzzmyster
I have been trying to find this lower facia online for awhile with no luck (2008 Street Glide), can someone send me a link? Thanks much...
Buzz
Gotham
Jul 6, 2016 08:10 AM
Tookey
Nov 18, 2014 06:56 AM
wattspd
Oct 1, 2009 03:07 PM
leohd
May 3, 2008 10:12 AM
twilliams
Feb 26, 2008 10:24 PM
