Fairing Screw Question
Old Apr 30, 2011 | 02:36 PM
Guitar4Him's Avatar
Guitar4Him
Default Fairing Screw Question
When I removed the fairing and re-installed it last night, I ran into a curious thing with the 4 lower screws. When I put the lower 4 screws in I was extremely careful to make sure they weren't cross-threaded. They went in easily about half way and then, got difficult to turn. It almost felt like they were cross-threaded. Anyway, I backed them out and checked the threads and they looked fine. So, I went on and tightened them down.
Today, I was telling my next-door neighbor about it. He's a mechanic and suggested that it may have been normal...the screws are designed to be difficult to prevent them from backing out under vibration.
Is he right or did I screw up? As I said before, I was very careful to prevent cross-threading.
Old Apr 30, 2011 | 02:50 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
These are not self locking style screws because the fairing nuts are brass & locking screws would mess them up. What most likely happened is that outer fairing shifted a little & the screw theads were rubbing against the inner fairing pass-thru hole just enough to provide resistance ... not a big deal.
Sometimes, you may have to snug them all a little then go back & tighten them all again. Or, when tightening one screw, reach with the other hand & move the fairing end thats opposite to the side you're working on.... Oh yeah, it can be a bitch at times to do.
Old Apr 30, 2011 | 04:35 PM
Jrsess's Avatar
Jrsess
I think your OK, keep an eye on them. With a touque wrench they sould be tightened to 20-30 inch lbs.
Old May 1, 2011 | 01:42 AM
JohnScrip's Avatar
JohnScrip
I have that problem with the lower right bolt. All the rest are fine. I just make sure I use that same bolt all the time (just in case it's screwy, so I don't mess up anything else).
Old May 1, 2011 | 01:52 AM
UK FXSTB's Avatar
UK FXSTB
The same thing happen to me and i was worried to untill i asked my mate who has taken his off loads of times and he put my mind at rest , i did re check them after my first long ride and they were fine.
It must be that i worry about things now im older that i wouldnt have given a second though about when i was a teenager.
Old May 1, 2011 | 03:08 AM
Potato_Potato's Avatar
Potato_Potato
I noticed something similar a while back - I chased the bolt holes with a pipe cleaner and blew them out with compressed air and also bought another set of screws. A close inspection of the screws revealed some of the threads were sort of flatten. I no longer use thread locker on them either as I suspected it was building up inside the bolt holes.
I just had the fairing off today and didn't notice a problem.
Old May 1, 2011 | 08:40 AM
Fathead2003's Avatar
Fathead2003
I had the problem with the lower left. I ran a threader thru and have not had a problem since. I now keep the same screw in the same location.
No Tyme
Jun 18, 2018 03:12 PM
ShrinerRider
Aug 17, 2017 12:42 PM
Jags93
Jan 4, 2011 03:51 PM
stro1965
Feb 3, 2009 07:57 PM
fryeca
Jan 7, 2007 09:11 PM
