twist grip sensor
Old May 29, 2011 | 03:27 PM
imskier2's Avatar
imskier2
28K on my 09 Ultra , never a problem.
Old May 29, 2011 | 04:43 PM
NOLAMike's Avatar
NOLAMike
With enough units sold there are bound to be failures on just about everything. The question to me is whether the FBW throttle set up fails at a higher or lower rate than cables. Anyone have stats on that?
Old Jul 6, 2011 | 12:19 PM
Milwaukee 1's Avatar
Milwaukee 1
23k on mine and I've just had the same problem. I guess it just depends on whether it happens to you or not if it's a common problem, but there's enough threads on here to let me think its not just bullcrap. I also called my service mgr and he knew exactly what the problem was when I told him what happened so I guess its common in his shop too.
Old Jul 6, 2011 | 12:35 PM
PistonPuller's Avatar
PistonPuller
Common or not, your bike is under warranty I would take it in.
Old Jul 6, 2011 | 01:07 PM
DPete's Avatar
DPete
If it had to happen you lucked out , if it was me I'd have probably been in Bum F^^k Egypt with no cell signal
Old Jul 6, 2011 | 01:14 PM
chilly1962's Avatar
chilly1962
22k on mine and it has got me twice in the last week. I reset the throttle and cleaned the pins where the cable plugs into the side of the intake. I also used some dielectric grease on the pins. Hoping for the best. If it does it again I will replace the twist grip sensor.
mongomark
Milwaukee Eight (M8)
Jul 23, 2019 09:26 PM
Da-mack
Feb 11, 2016 12:15 AM
fishdo13
Jul 18, 2014 05:09 PM
Hoosier bird
Feb 25, 2014 06:07 PM
inmanz
Jun 20, 2011 10:34 PM
