Noise in turns
Old May 31, 2011 | 08:38 AM
r0ckie's Avatar
r0ckie
Default Noise in turns
Just lately my 09 Ultra has started making what sounds like tire noise when turning. Happens when turning either way but louder on a left turn. I checked the tire pressure and added a few pounds to both front and rear as both were a little low but still have the noise. Both tires appear to be wearing evenly. About 7K on the front and 17K on the rear. I looked in the manual for bearing service intervals but no info on re-packing them so I guess they're sealed?. Bike has 27K on it so I don't think the bearings should be an issue anyway.
Any help would be appreciated.
Thanks,
R0ckie
Old May 31, 2011 | 08:46 AM
'05Train's Avatar
'05Train
Sounds like either tread cupping or the transition from the flatter center of the tire to the less-worn sides.
Old May 31, 2011 | 08:49 AM
Ronp42's Avatar
Ronp42
Account Retired
It's more than likely the Dunlop tires. Are you running the 408F and 407 rear? My 09 made a loud whining noise laid over in a curve. I ran 40 PSI in both tires riding solo. 42 in rear two up! The 09's had a tire recall on the 407F. Your's is probably the 408F now. Your wheel bearings should be ok unless you have damaged them with a power washer. I recently replaced my rear tire with an American Elite. I like it better than the 407 Rear. The front 408F still whines, but not as bad as the 407F did.
Old May 31, 2011 | 09:14 AM
oopster510's Avatar
oopster510
5th Gear
Default my 09
just my 2 cents.. have the bearings checked... my 09 ultra had a rear bearing go out at about 12k...
Old May 31, 2011 | 09:31 AM
DPete's Avatar
DPete
Bet it's the back tire when you lean, mine did the same toward the end of the tire.
Old May 31, 2011 | 11:50 AM
h01waterman's Avatar
h01waterman
I noticed the same thing on my 2010 limited from the day I got it. The dealer has convinced me it is the tires. We have 15,000 miles on mine and am planing a long ride this summer. Maybe we will switch brands and find out if this in fact the cause.
Old May 31, 2011 | 12:08 PM
Dallas 13's Avatar
Dallas 13
The only time I had noise like you describe is when the belt is too tight.
Twice, after tire changes, the belt was adjusted too tight. Do it myself everytime now.
Old May 31, 2011 | 12:13 PM
jberg's Avatar
jberg
OEM front tires have cupping issues. 17K on the rear tire is a lot of miles. Probably time for new rubber and I'll bet the noise goes away.
Old May 31, 2011 | 12:42 PM
rg_dave's Avatar
rg_dave
Check belt tension (more of a squeal than a whine, it will make noise when either too tight or too loose) and tire cupping (more of a whine than a squeal).
Old May 31, 2011 | 01:30 PM
keith_stepp's Avatar
keith_stepp
Originally Posted by '05Train
Sounds like ... tread cupping ...
Yup. Been there done that going on 3 times now. Was real bad on the front tire, not so bad on the rear, and now I am starting to hear it again on the front, which I have about 12k on. Getting 17k out of a tire is actually pretty good, so I would inspect that rear tire; bet that is the source of the noise.
