What effect does changing the spark plug gap have?
Old Jun 3, 2011 | 04:23 PM
riteway's Avatar
riteway
Originally Posted by fabrik8r
I've always been an advocate of indexing, it positions the ground strap so it doesn't shield the spark from the air/fuel charge.
My Brother was a 1/4 mile racer and did indexing but i never thought about it on my HD?... id like to see a pole on how many guys index their plugs and do they think it makes any difference.
If it really does help,seems like an ez performance improver!!!
Subscribed...
Thanks.... Tim...o~`o.....................................
Old Jun 3, 2011 | 04:34 PM
mrfikser's Avatar
mrfikser
I believe the difference in the specs. is for wear..say you are suppose to "be" between .038 and .044 ..you set it at .038 and as the plug is used the gap will expand with wear..when you reach .044 you need to regap the plug..but most people just toss them and install new long before that happens...That's my story and I'm sticking to it!!
Old Jun 3, 2011 | 05:03 PM
dstrat1's Avatar
dstrat1
In the racing world, I first thing we see is guys buying more motor.(thinking it will make them faster)....My motor man took the money but told me ...Dave, the driver is worth seconds, the setup is worth tenths, the motor is worth hundreths (of a second)...One track day is worth more than most people can ever afford to do to their motor...... ditto for suspension...It is humbling to learn, but you usually are not slow because of the motor..
A little like talking to saleman in a high dollar (bicycle ) store about overweight customers spending an extra 1000 for a lightweigt bike and then hanging 4 water bottles on it.....
Old Jun 3, 2011 | 05:30 PM
jmacdonald5's Avatar
jmacdonald5
..indexing plugs on an average Harley?....won't do anything to the engine, or performance that matters...no harm...but no point...to each his own...
Old Jun 3, 2011 | 05:45 PM
speakerfritz's Avatar
speakerfritz
on an 07 ultra, changing away from stock plugs craps out the anti-knock feature, I tried plugs that were supposed to be gooder....but the loss of the anti-knock was anoying, so I went back to stock....I have to believe that change the gaps out of range could also bring havoc to the anti-knock system.
Old Jun 3, 2011 | 06:06 PM
fireaxxe's Avatar
fireaxxe
You want to set you gap close to the smallest setting for longevity. The tighter the gap the longer you can go between setting the gap the spark is strongest at the lower end of the measurement as the gap increases the spark is a little weaker because it has to travel a longer distance and this takes energy to accomplish. The smaller gap causes the spark to travel very fast and you want the spark to stick around long enough to ignite the fuel mix so if you go below the min setting you may have a misfire the same will happen if the gap is to large. I like to use the rocker arm shims to index my spark plugs they come in .005", .010", .015" and up to .025" I think they were originally used on the 80's model Shovel head engines and these are steel shims.
Old Nov 20, 2011 | 02:01 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
I tried gapping the plugs at .038 and thought it lacked the power it had before. I then regapped them at .043 along with indexing them and it seemed to run a little stronger than before. JMO.
Old Nov 20, 2011 | 02:50 PM
SIDECAR BOB's Avatar
SIDECAR BOB
google Aunt tilly's spark plug gap guide by chris jacobs, he used to make on of the first electronic aftermarket ignitions for cars. it explains what larger and smaller gaps will do and the efect the have. Its based on v8 but woiuld be similar results in a v twin. not sure how big of effect it have but interesting reading all the same. couldnt get a good pic of the chart to attach sorry
Old Nov 20, 2011 | 02:53 PM
Gearhead3's Avatar
Gearhead3
Subscribed...
I've done it to my RG and my LS1. I've also side gapped the plugs in both. It's cheap, it works, (you'll notice it more in some applications...not so much in others) plus I like to "tinker" with things. Hell, I run Mobil 1 synthetic in my push mower! (and yes, the plug is side gapped and indexed!!) I'm just a gearhead at heart and try to make IC engines run as efficiently as is possible. It's a disease.
Old Nov 20, 2011 | 03:08 PM
NickD's Avatar
NickD
I've always indexed my plugs. But I know it may be like hot chicken soup when you have the flu. It may not really improve things but it can't hurt and it does make you feel better . . .
