What effect does changing the spark plug gap have?
Old Jan 25, 2012 | 02:14 PM
  #41
fabrik8r's Avatar
fabrik8r
Originally Posted by mike_oh
I want to index my plugs but where do you get the rings? I bought some 14mm from Jegs but they fit very loosely. Thanks!
Its a bitch to find 12mm washers, I think the kits available are way too expensive for what they are so I made my own. Got close imperial measurement copper shims from McMaster Carr, didin't have metrics, Had to build a fixture to hold a stack of washers and drill them out. anyway they can be purchased. Jacobs and Moroso used to make them also, might try Jegs or Summitt too.
http://youroilshop.com/plugs.htm
http://www.zippersperformance.com/ca...=583&prod=2280
http://www.debrix.com/SPARK-PLUG-IND...p/3-271-mw.htm
http://www.sudco.com/spark.html
Just google "12mm plug indexing washers"
Old Jan 25, 2012 | 02:44 PM
  #42
mtclassic's Avatar
mtclassic
summitt has them but strangley enough I have always indexed my plugs and generally you can index them without added washers. Some times if they don't index switch them around and they will. Early bmw oilheads had a real bad lean surge and one of the ways to get rid of the lean surge was to index the plugs.
Old Apr 2, 2012 | 04:49 PM
  #43
FRANK1946's Avatar
FRANK1946
3rd Gear
Thanks for the info.
Old Apr 2, 2012 | 08:43 PM
  #44
fabrik8r's Avatar
fabrik8r
Just check the desription close, I've only seen 14mm at Summit and Jegs
Chuck U. Farley
2014-2024 Touring Models
15
Mar 15, 2015 02:23 PM
ib5150
May 29, 2013 11:40 AM
srp00702
Engine Mechanical Topics
Sep 24, 2009 11:50 AM
kenward
Jul 31, 2009 08:42 AM
Shift_4lo
Mar 11, 2006 03:37 PM
