Spark plugs
Old Jun 4, 2011 | 12:16 PM
speakerfritz's Avatar
speakerfritz
just changed the oil last week, cleaned
well, if your spark plug analysis doesnt resolve the problem, recommend you check the level of your oil (which often on sputter bikes is on the high side cold) and drain a little with a siphon so that the oil level is in between the middle and lower level when hot.
Old Jun 4, 2011 | 12:23 PM
46u's Avatar
46u
Other then the plugs that came in mine off the show room floor I run Autolite 4164 for 86K plus miles. I change mine every10K like the manual recommends. They still look good when I take them out but for $2 each just cheap insurance. On any plug make sure you check or set the gap.
Old Jun 5, 2011 | 08:52 AM
strtarrow's Avatar
strtarrow
After changing the plugs still had the problem. Went to a dealership for a benefit run. Happens to be one of my favorites regarding parts and service. The parts guy, very sharp suggested changing the plug wires. Rode a couple hundred miles yesterday and the bike ran great. BTW, the wires I had on there were braided stainless and only had them a couple months. Looked cool but ended up giving them to a guy riding a Dyna and he could use them to replace his obviously in need of replacement long wire. Surely both did not go bad so will hopefully work for him.
Old Jun 5, 2011 | 09:12 AM
TWIN CAM 96's Avatar
TWIN CAM 96
6R12 standard HD plugs there only $3.95 ea. changed mine yesterday at 10,000 miles they look just like the new one's except for the sandy brown color saved the old one's for just in case I need to change out on the road somewhere.
harleyglen
Oct 10, 2013 10:51 AM
mrammo
Feb 16, 2012 05:53 PM
cpudoc
Sep 21, 2011 01:56 PM
cav1429
Mar 7, 2010 12:29 PM
cws176
Aug 17, 2007 12:07 AM
