Dunlop tire problem
Old Jul 7, 2011 | 08:17 PM
chipofsc's Avatar
chipofsc
Originally Posted by frenchbiker
A 200 tire on a Street Glide? AFAIK, that's not stock. Stock is 180/65-16 on 09 and up models, like for all Touring bikes.
The 200 on the Fat Boy is a 17" tire. Did you put a 17" wheel on your Street Glide? Did you have to modify something, besides the wheel, for the tire to fit?
No the streeglide has a 180/16 and the fatboy had a 200 dunlop. Not sure the wheel size. I sold it with the stock tire on it.
Old Jul 7, 2011 | 11:17 PM
Bluehighways's Avatar
Bluehighways
Tire Cupping is caused by large Caster Angles. The Caster Angle on a bike is called "Rake" on the front wheel. Large Caster Angles cause a Tire to squirm in a turn. The distortion of the tire in a turn is what causes the wear pattern called Cupping. The greater the Caster Angle the more distortion. Over inflating the tire may help to reduce the effect, and large tread blocks, as well as aggressive and/or a great deal of cornering will tend to accelerate the effect even on Rear Tires that have a static Caster Angle of 0 Degrees.
Old Jul 8, 2011 | 12:39 AM
j1mmy's Avatar
j1mmy
i have a d404 on my EG.it has two summers on it probably less then 5-6k miles..it is completely bald in the middle third..i don't think i will put a donlop back on my bike..thinking good year??.. actually im cheap,im looking for a good used tire
skibum0607
Apr 10, 2017 07:48 AM
rvkersh
Mar 29, 2017 11:19 PM
Rock Chalk
Aug 22, 2012 03:39 AM
tpierce67
May 25, 2012 01:21 AM
2007fxdc
Mar 22, 2008 10:42 AM
