One More Swing Test Question
Old Jul 5, 2011 | 07:18 AM
asm481's Avatar
asm481
Default One More Swing Test Question
I have searched and read but still a bit confused. I want to do a proper swing test to check my steering head bearing tension. This is for my 2002 Road King. I know level and remove extras like GPS mount, windshield, cup holders but what about the Nacelle, clutch cable and throtle cables? Thanks in advance for your time.
Old Jul 5, 2011 | 07:46 AM
Jags93's Avatar
Jags93
I haven't done it myself yet but the manual says to remove the clutch cable if it seems to influence the swing - i.e. bind up.
Turn the front wheel until contact is made
with the left fork stop and then let go. The wheel should
swing from side to side, finally stopping in either the third
or fourth swing. If it stops in the third swing, it should be
at or after the center or straight-forward position.
If the clutch cable or main harness appears to be influencing
swing momentum, proceed as follows and repeat the
previous step:
Clutch cable:
Disconnect clutch cable at hand lever.
Release cable from P-clamp fastened to upper fork
bracket (FLHR/C), remove from inner fairing
(FLHT/C/U), or release from cable clip on instrument nacelle (FLTR).
Old Jul 5, 2011 | 11:32 AM
patsfan's Avatar
patsfan
Windshield - yes, clutch cable if it seems to inhibit swing.
Nacelle's got to come apart if it needs adjusting but I'm sure you know that.
Zanthamos
Jul 10, 2017 07:45 AM
Baja38ss
May 26, 2015 11:34 AM
DynaJ
May 9, 2012 06:41 PM
jl207299
Mar 28, 2012 11:20 AM
BruceHarrisJr
EVO
Dec 12, 2007 09:20 PM
