Stereo Question
Old Jul 10, 2011 | 03:05 PM
hellmut73's Avatar
hellmut73
Default Stereo Question
I would like to use the Arc 125.4 in my Ultra. Does anyone know if anyone sells a bracket to attach this amp to the radio? I thought that I read somewhere that you have to cut the fairing to use this amp? Does anyone have expirence with this amp? Thanks.
Old Jul 10, 2011 | 04:10 PM
Harleypingman's Avatar
Harleypingman
Eastside HD in your neck of the woods offers a package using the Arc 125.4 that includes a modified right vertical fairing bracket.
141Starlifter (Scott) sells a bracket to mount the amp over the HK radio, and the CB/XM/Ipod modules (two only) below the radio. Myself and several others here have used it for other amps, including the Arc 125.2 which is similar in height and depth to the 125.4.
sublime_ac (not sure about spelling), a member here, posted that he bought the bracket from Eastside and installed the Arc 125.4. You can probably use the search function above and use Arc 125.4 as the search term an find his posts on the topic, as well as one by another member who had the Eastside HD 125.4 package installed on his bike.
I'll find the post I did on Scott's bracket and edit this post to supply the link.
Good luck with your project.
I ended up using the Rockford Fosgate 300W, 4-channel, 4 ohm impedance amp and am very happy with it.
Carl
Old Jul 10, 2011 | 04:20 PM
Harleypingman
Here's a link to the Eastside HD 125.4 installation with pictures.
https://www.hdforums.com/forum/touri...t-at-80mp.html
Carl
Old Jul 10, 2011 | 04:24 PM
Harleypingman
And here's the thread with Scott's bracket:
https://www.hdforums.com/forum/touri...d-modules.html
Carl
Old Jul 11, 2011 | 11:36 PM
hellmut73's Avatar
hellmut73
Thank you for taking the time to look up all those links. I appreciate it. I am trying to figure out my stereo upgrade and I am finding it a little overwhelming. Thanks again for your time!
Old Jul 12, 2011 | 09:05 AM
Harleypingman
You're welcome. I'd recommend the RF PBR300x4 (300W, 4-channel, 4 ohm impedance amp) and Scott's bracket. The bracket makes the installation of the amp very simple by moving the CB module below the HK, and the bracket's top shelf is pre-drilled to attach the RF amp. And, 75W per channel is plenty of power IMO. RF supplies the harnesses for the amp inputs and outputs. This is the thread on my installation of the RF amp, etc.:
https://www.hdforums.com/forum/touri...annel-amp.html
Good luck with your research.
Carl
rome304
Audio Systems
24
Jul 1, 2013 04:58 PM
Harleypingman
Audio Systems
18
Oct 7, 2011 01:24 PM
drive2live2ride
Apr 5, 2011 11:09 AM
SCJE8
Dec 16, 2010 08:21 PM
Harleypingman
Sep 14, 2010 03:43 PM
