Not a solution but trouble shooting tip. Get a circuit breaker the same size as the fuse and put small spade connectors on the end of some wire so you can insert them where the fuse goes. Then when it pops, you can reset it instead of going through a ton of fuses while you troubleshoot
And as a last ditch frustration solution, put a large gauge paperclip across the fuse and then just follow the smoke to guide your way to the short.
Good luck! Finding shorts can be a bitch.
our wire a headlight in series and when the glow gets dim or goes away your there.
[QUOTE=MURPHCC1;20219668]You people do realize you're posting to a 10 year old thread right?
And the OP hasn't been on here in 6 years........
So I bet he fixed it........]
Well sh*t .looks like this people stepped right into it.
