Blowing fuses
Old Aug 7, 2011 | 01:13 PM
bandanaman's Avatar
bandanaman
Stage IV
Default Blowing fuses
Hi, New to the forum. I just bought a 2012 Ultra Limited and tried plugging my satellite radio into the cig lighter for power and for some reason it blows the fuse when i turn on the ignition. I know in the manual it says not to use it, but i know people who do with no trouble. I can plug my gps into it and it works fine. Any ideas on what could be causing the fuse to blow when i turn on the ignition. The cig lighter seems to work fine. Going through a lot of fuses trying to figure this out.
Old Aug 7, 2011 | 01:36 PM
HdShark2011's Avatar
HdShark2011
I had a fuse blow on my recent trip when I plugged mine in to the lighter. But I did it when I had the heated grips on. Replaced the fuse , turned off grips , no more problem. Just a thought.
Old Aug 7, 2011 | 02:07 PM
bandanaman's Avatar
bandanaman
Stage IV
Yea, I thought of that too since they are on the same fuse, but my bike was parked in the garage when i was trying to hook the radio up so i didn't have the heated grips on. I'm wondering if it could be a bad outlet?
Old Aug 7, 2011 | 02:29 PM
CIB1Infantry's Avatar
CIB1Infantry
more than likely not a "bad outlet" since you say that you can plug in your gps and the lighter works...
does this only occur when starting or when you move the switch to ignition?
does it happen if you already have the switch in that position and then plug in?
strange issue.
Old Aug 7, 2011 | 02:56 PM
bandanaman's Avatar
bandanaman
Stage IV
If I have the ignition on and then plug in the radio it's ok, when i shut off the ignition and then turn it back on while the radio is still plugged in, that's when it blows the fuse. It doesn't make sense to me. I'm thinkin something is grounding out when i turn the ignition back on.
Old Aug 7, 2011 | 09:39 PM
speakerfritz's Avatar
speakerfritz
read this somewhere before...check the polarity of both your outlets and your accessories.
Old Aug 7, 2011 | 10:06 PM
1plumr1's Avatar
1plumr1
try it in your cage and see if it blows a fuse. If it does, it's in your sat radio plug or wiring.
Old Sep 25, 2011 | 06:46 PM
Knipper's Avatar
Knipper
Stage II
I have the same problem with my 2010 Electra Glide FLHTC, my Sat radio works for a day or two then blows the fuse, I was thinking of moving from a 15 amp to a 20 amp fuse. Would moving up 5 amps hurt the electrical system? Anything else to check
Old Sep 25, 2011 | 06:52 PM
1flhtk4me's Avatar
1flhtk4me
While it may work,I would not take the risk.
SamB
Oct 10, 2020 06:06 PM
clackavosticus
May 4, 2018 08:19 AM
Hammz
2014-2024 Touring Models
15
Sep 28, 2015 10:47 AM
dlrshort
Mar 14, 2011 07:08 PM
wing_rdr
Apr 14, 2010 08:09 PM
