Neutral lite
Old Aug 11, 2011 | 06:45 AM
relli's Avatar
relli
Default Neutral lite
my neutral lite went out on me. is that a replaceable bulb? just take the frt fairing off? anyone have the bulb/part # ? thanks
Old Aug 11, 2011 | 06:55 AM
geezer glide 56's Avatar
geezer glide 56
No It is not a replaceable bulb...You have to replace the cluster...The first place I would check would be the neutral switch on top of the transmission...It is possible that it is unplugged...To check it remove the wire from the neutral switch turn on the ignition switch and ground the wire going to the neutral switch...If the neutral light lights up the problem is your neutral switch.
Old Aug 11, 2011 | 08:32 AM
relli's Avatar
relli
interesting . but i cant see a switch. ill have to check the book when i get home. i see a 3 wire plug left lower but looks like its integral to the case.
Old Aug 11, 2011 | 01:47 PM
62hdbiker's Avatar
62hdbiker
Three wire plug is to your stator. Neutral switch is on top of trans on right side of bike. Do what previos post said to test.
petewood70
EVO
15
Jun 19, 2020 05:08 PM
BACADon
Oct 30, 2015 04:47 PM
HDmikie
Jan 7, 2012 07:20 PM
Worped
Mar 23, 2010 11:36 PM
schienbein
Aug 27, 2009 01:59 PM
