Starter issues - need help!
Old Aug 13, 2011 | 06:45 PM
twistedcherokee's Avatar
twistedcherokee
Check the starter bolts to see if they are loose, I think there was a bulletin out for changing the torque on the bolts. Got a friend that did that a couple of times (no crank), he checked his bolts after I told him about the bulletin & they were loose. Has not had a problem since. Good luck
Toby
Old Aug 13, 2011 | 07:52 PM
bnfzep's Avatar
bnfzep
Originally Posted by soft 02
Time to clean up the solinoid contact washer in the starter. If you hit it and it worked its due to wear on the solinoid and you dont even need to remove the starter. A little work with a file and your done.
It may be obvious, but be sure to disconnect the negative terminal of the battery before gaining access to the solenoid. It is wired directly to the battery and remains live regardless of the position of the ignition switch. Sorry if this is common sense, but it is worth noting.
Old Aug 13, 2011 | 07:56 PM
RANGER73's Avatar
RANGER73
Dude just replace the relay. Just because it's clicking doesn't mean it's closing the contact between post 30 and 87 on the relay. The reason I know this is because I just tested and repaired the relay on my bike.
Old Aug 13, 2011 | 09:09 PM
soft 02's Avatar
soft 02
2nd that! And I would only chase the soliniod after confirming a good battery and connections and relay and fuse and switch and fob and starter bolts.
Old Aug 14, 2011 | 05:35 AM
bbflhrs's Avatar
bbflhrs
All good suggestions but since it the bike started after hitting the solenoid wouldn't that point to the solenoid as the problem? How could the relay switch be bad, and then work after hitting the solenoid? I would very much like that to be the problem as it is an easy fix.
Old Aug 14, 2011 | 11:38 AM
RANGER73's Avatar
RANGER73
I thought it was the relay you were hitting. Check the connections on the starter. Make sure you disconnect the neg. terminal on the battery first. There's not much room under there, don't want to short anything out. As stated earlier, if you jump a positive to the green from the starter relay that will energize the starter solenoid, jump it 6 or 8 times, if the starter turns every time you've ruled out the starter solenoid and your back to the relay.
You can pull the relay out of the plug enough to get test leads on the terminals to check input and output voltages.
Old Aug 14, 2011 | 12:51 PM
bbflhrs's Avatar
bbflhrs
I guess I am confused. The relay I'm talking about is in the fuse box beneath the side panel. Isn't that the relay? Since I hit the solenoid yesterday, the bike has started every time. I probably started it 5 or 6 times just to see if I could duplicate the problem.
Old Aug 14, 2011 | 06:04 PM
RANGER73's Avatar
RANGER73
No, the solenoid is on the starter. The relay is next to the fuse box. You need the relay because the start button on the bar can't handle the starter load.
If that's the thing your hitting, it's a small box, about 1" square. That's the relay, it clicks when you push the start button.
MotleySTL
EVO
11
Nov 22, 2024 04:49 PM
jimmyd48
Shovelhead
24
Mar 4, 2020 04:29 PM
walker350
May 21, 2014 06:14 PM
oldiron74
Ironhead
Jul 7, 2011 08:27 AM
E9er
Sep 25, 2010 08:31 PM
