Bike sitting for 3 years
Old Aug 23, 2011 | 05:59 PM
thelary07's Avatar
thelary07
6th Gear
Default Bike sitting for 3 years
I have an '07 FLHTC with 7500 miles on it that I parked in the garage 3 years ago..(don't ask),have started it on an intermittent basis about 4 or 5 times a year and run it for abut 5-10 minutes at a time. Want to take it out on an extended trip and wonder what maintenance issues should be addressed before I do. The trip will be about 1400 miles. New battery is in, what else is needed to insure trouble free trip? Any input is appreciated. Thanks..PS dealer can't get me in for two weeks so I'll have to do it myself.
Old Aug 23, 2011 | 06:11 PM
Glidedsternfan's Avatar
Glidedsternfan
Exclamation Have you....
....ridden it at all in preparation for this 1400mi trip?
Check the tires, flat spots, dry rot.
Do you have AAA?
GSF
Old Aug 23, 2011 | 06:12 PM
hdelectra's Avatar
hdelectra
I would definitely change the fluids in all 3 holes. Perhaps the air filter as well.
Old Aug 23, 2011 | 06:16 PM
SeeMeDo's Avatar
SeeMeDo
would really look at the tires for dry rot and change the fluids. I would be worried about anything that has a seal, forks, front end, breaks, and shocks even anything with grease in it. Would definitely do a test run of about 60 miles out with a stop and return just check everything out.
Old Aug 23, 2011 | 06:28 PM
thelary07's Avatar
thelary07
6th Gear
thanks for the input..I will definitely change the fluids and do a test ride, wonder about the fuel filter..is this a tough thing to change..got the books but wonder if necessary since the tank has been nearly empty and have added Stabil to what gas there was in there.
Old Aug 23, 2011 | 06:39 PM
kingkingking's Avatar
kingkingking
I would do all 3 oils.
You definitely need to change the brake fluid.
I wouldnt bother with the fork oil, or the shocks, or wheel bearings, they will be fine.
I would inspect the tyres for signs of them perishing, but as long as she was stored in a garage or shed its unlikely they would be a problem.
Siphon out all the old fuel and put in new stuff. Off you go.
Old Aug 23, 2011 | 06:52 PM
thelary07's Avatar
thelary07
6th Gear
Feeling better about this trip with each passing post...Glidedsternfan...absolutely DO have my AAA up to date..Didn't think Syn 3 was so darned expensive though...can use it in all three apps? Engine, Primary and Trans? Can this be right?
Old Aug 23, 2011 | 06:56 PM
twistr's Avatar
twistr
As many have said...change fluids, check tires....try and go for a ride (at least 150 miles) and make sure the bike feels solid.
Old Aug 23, 2011 | 07:12 PM
rkoivisto's Avatar
rkoivisto
Default 3 Years?
Wouldn't worry about it. That's about typical between rides for the majority or Harleys.
It should be good and rested!
Old Aug 23, 2011 | 07:15 PM
Ratkiller's Avatar
Ratkiller
I'd be looking at the wiring. Mice like to chew the insulation and if it's been sitting they could have done some damage.
Ratkiller
