Security Light Stuck On..
Old Sep 15, 2011 | 09:35 AM
bagman1's Avatar
bagman1
Most definately take it to the dealer. Maybe strike up a conversation about the issue and see if there is an ongoing problem that you can share here with the forum.
Old Sep 15, 2011 | 09:41 AM
davidsdad's Avatar
davidsdad
I will give it a try!!
Old Sep 15, 2011 | 12:09 PM
Hammy's Avatar
Hammy
TSSM isn't very cheap but you're in warranty so they should just swap it out.
If the short gets bad enough it will drain down the battery when parked a few days, also it may keep the bike from running at all, so get it swapped while you're still running.
Old Sep 15, 2011 | 04:13 PM
VINNIE JAMES's Avatar
VINNIE JAMES
how do i retrive codes on a 2003 electra glide? after it warms up...my bike is falling on its face when i crack the throttle. just replaced the plugs and map sensor but im still having the problem when its warm...thanks,vinnie
Old Sep 15, 2011 | 04:47 PM
2black1s's Avatar
2black1s
I believe the process posted earlier by Matt0987 (post #11) will work for your '03.
Old Sep 15, 2011 | 04:52 PM
davidsdad's Avatar
davidsdad
Okay guys I figured out my problem with the reason my "red key" was on! I pulled my clutch purch off and evidently pinched a wire when reassembling it after changing my bars to the Heritage bars. I made the repair and performed the DTC and cleared the code. Problem solved!!!! Thanks for taking the time to reply!!
BuzzMe
Jun 30, 2015 02:17 PM
Melo4x4
Jul 21, 2014 07:15 PM
chefjohnnyb
Jul 6, 2011 03:44 PM
mrbuck
Jan 19, 2009 09:44 PM
raw
Sep 4, 2008 06:33 AM
