Speaker installation help
Old Sep 15, 2011 | 10:13 PM
SG Mike's Avatar
SG Mike
Hi Kdfoster:
Go to the link below and click on the product picture. Your speakers should look like that if not then you must have a defective set.
Mike
http://www.crutchfield.com/p_107DB52...k_521&skipvs=T
Old Sep 16, 2011 | 05:51 AM
00rg's Avatar
00rg
Originally Posted by SG Mike
Hi Kdfoster:
Mike
Those are the db speakers, he has the mm series.Your speakers wont look like these.
Old Sep 16, 2011 | 06:41 AM
00rg's Avatar
00rg
Originally Posted by kdfoster
The connections on the speakers are all different sizes and fit only one way, so I have that right. I hooked the stripped ends from the crossover to the stock speaker wires, but no sound. I think there must be a bad connection somewhere.
Do the factory speakers work if you hook them back up? If they do you have something wired wrong or a problem with the speakers. To test the speakers take a small battery like 9v or aa and take a wire and hook from the battery to the speaker with polarity correct and you should hear a faint bump noise if you do the speakers are ok.Also try to skip over the crossovers and hook up directly to the polks upper or lower spades 1 at a time and see if all speakers work at a low volume if they do it could be the crossovers. Were these speakers new or used?
Old Sep 16, 2011 | 09:26 AM
kdfoster's Avatar
kdfoster
I appreciate all the help from you guys. I finally got some sound, but it wasn't as good or loud as the stock speakers. I got frustrated and put the stock speakers back in. It wasn't a lost cause because I got some good experience taking the fairing off and seeing how different things look inside. If I do something in the future, I'll just make sure I get the plug and play speakers. I don't know enough about speakers to know if the speakers or defective ,or not hooked up correct. Thanks again
DaddyKnuck
Audio Systems
Jun 7, 2017 10:38 AM
Ragz Ultra
Audio Systems
28
Jun 21, 2015 07:28 PM
margin5
Audio Systems
49
Sep 4, 2014 09:10 AM
Harleybike
Oct 20, 2011 09:11 PM
Dino3981
May 10, 2007 07:34 PM
