LeNale / Parade Fan Question
Old Sep 18, 2011 | 05:28 AM
jamesroadking's Avatar
jamesroadking
Default LeNale / Parade Fan Question
Just a thought. Can the LeNale or HD Parade fans be reversed to suck the hot cylinder head air out and expel it to the left side of the bike?
The thought of blowing more hot air to the already exhaust heated right side of the bike just doesn't make sense, plus blowing hot air into the A/C doesn't do any good.
Old Sep 18, 2011 | 09:09 AM
pappy42's Avatar
pappy42
Ahhh; the old suck vs blow controversy.
Old Sep 18, 2011 | 09:21 AM
DannyZ71's Avatar
DannyZ71
As long as it's properly identified as to what it is supposed to do, there should be no controversy on this matter. I think sucking will probably achieve the desired result better than blowing on it.
Old Sep 18, 2011 | 09:25 AM
jamesroadking
This is on a 2010 FLHTK.
Old Sep 18, 2011 | 09:47 AM
1plumr1's Avatar
1plumr1
normally on a fan you can change direction by reversing polarity of the wiring. But I think you will not achieve your desired effect, pulling air takes a lot more force than pushing.
Old Sep 18, 2011 | 10:15 AM
3/4 life crisis's Avatar
3/4 life crisis
Reversing polarity will do it. Sucking air out might not be as efficient, though. Since the fan is ~2-3" away from the heat source, it might just pull air from around the housing instead dead on from the cyl. Just a thought....
Old Sep 18, 2011 | 11:01 AM
2black1s's Avatar
2black1s
I agree.
I know the fan works very well in it's intended configuration. Here's some test data on precisely how well. https://www.hdforums.com/forum/touri...test-data.html
I don't have any testing to validate the fans performance wired to reverse the airflow, but my gut feel is that it wouldn't be nearly as efficient.
Old Sep 18, 2011 | 12:04 PM
Morris9982's Avatar
Morris9982
You might want to look at the design of the blades also. Some fan blades are optimized to move air in one direction. If you reverse the direction, air flow may be significantly less. I've never looked at the fan blades on either the HD or the other unit so I do not know how they are designed.
I have the HD unit on my bike with the thermostat switch that came with the unit installed as well as an override switch so I can turn on the fan any time and it works very well when used as it came out of the box.
Old Sep 18, 2011 | 12:13 PM
DannyZ71's Avatar
DannyZ71
Originally Posted by jamesroadking
Smart *** responses not appreciated.
Lighten up Francis.
And I agree with others responses. Plus, you're not just blowing hot air away from the cylinders, you're pulling in (hopefully) cooler air and blowing that across the cylinders.
Old Sep 18, 2011 | 03:49 PM
Cozmic's Avatar
Cozmic
Couple more years and they'll all be water cooled. Then you can upgrade, and this issue will be solved.
