Wire problems
Old Sep 27, 2011 | 10:38 PM
harley girl 4's Avatar
harley girl 4
Stage III
Default Wire problems
I have an 09 Road King with 57,000 miles on it. My bike started bucking as if there was water in the gas, it turns out the wire harness was rubbing on the battery and wore through to the wires causing it to short. Is this a common problem? Has anyone else experienced this issue? Thanks for any input.
Old Sep 27, 2011 | 11:03 PM
mkguitar's Avatar
mkguitar
welcome to the forums.
3 years is kinda quick, but 57,000 miles is more than 95% of 09's have on em.
You are a pioneer and discovering problems for the rest of us.
mind posting a photo or description so I can check same location on my 09 ?
I have had wires rub through on various bikes over the years- fix would be to strip back insulation, use a crimp butt connector and heatshrink tubing over top.
can't solder wires on a bike, the wires break at the joint due to vibration.
Mike
Old Sep 28, 2011 | 09:25 AM
EastSideBikerTrash's Avatar
EastSideBikerTrash
Have you replaced the battery before this happened or ever had it removed? Just trying to figure out if the harness was placed in a bad place?
Old Sep 28, 2011 | 02:19 PM
Yukon42's Avatar
Yukon42
Originally Posted by mkguitar
........can't solder wires on a bike, the wires break at the joint due to vibration.
Mike
Say what???? I've been soldering wires for YEARS on bikes with no problems; never heard of anybody having any problems when soldering done correctly. OTOH, seen many, many nightmares caused by butt connectors....
Old Sep 28, 2011 | 10:14 PM
harley girl 4
Stage III
Smile wire problems
Mike
Thanks for the input. My husband and I did just that. There were 4 wires that we had to repair, unfortunately that didn't fix the problem. We did find out about the codes and I need to replace a sensor.
Old Sep 28, 2011 | 10:20 PM
harley girl 4
Stage III
Default wire problems
I didn't touch the battery, the harness is in a bad spot. I live in NY and we have lots of bad roads so my bike gets bounced around a lot. Thanks
Vandinroth
Electrical/Lighting/Alarm
Jul 1, 2021 07:44 AM
dmarion
Jul 8, 2015 10:05 PM
cdestuck
Mar 26, 2013 08:54 PM
MAGSRFFR
Jan 13, 2011 05:21 PM
Getyurmotorunnin
Aug 3, 2009 09:26 PM
