Ohlin #3-1
Old Sep 28, 2011 | 12:53 PM
steve047's Avatar
steve047
Default Ohlin #3-1
I called Howard and was told to buy a Caliper from Harbor Freight would be helpful and to read up on his website. I want to thank him for that as I had no idea about shocks and what I wanted.
a few weeks go by and after reading every pdf file on Howard's website and every thread on this site I called Howard and ordered the #3-1's. I have a FLHRSE3 and wanted to maintain the 1 inch lowered height.
the shocks were delivered and they are beautiful!!! Called Howard a couple hours later and he walked me through the install and was told to go ride the bike and call him back. I was only able to ride a few miles but could tell a hudge difference.
I'm a primary caregiver for a parent who is on Hospice so it's hard for me to get out and ride right now but I'll finish this review in the next few weeks.
for now I just want to thank Howard and I will finish this review soon
Steve
Old Sep 28, 2011 | 01:26 PM
tj316's Avatar
tj316
break them in ,set the sag and then play with the damping adjuster and you will love them
Old Sep 28, 2011 | 04:12 PM
bigdaddy33's Avatar
bigdaddy33
I put Ohlins (which I bought from Howard) on my FXDL about a year and a half ago. Great shocks! You made a great decision.
Old Sep 28, 2011 | 08:06 PM
Edhglide's Avatar
Edhglide
Give them about 1000 miles then recheck the rider sag and try 14 or 15 clicks on the value. I love mine
Old Sep 30, 2011 | 10:06 PM
El Agouti's Avatar
El Agouti
Stage IV
I have a 2008 Road King Classic that I put on Ohlins (2-2A). I also got them from Howard. What a difference especially in the corners hitting bumps. I also put on some Ricor intiminators and this really help the jarring I used to feel in the handle bars.
Old Sep 30, 2011 | 10:33 PM
Buckinfitch's Avatar
Buckinfitch
the OEM HD air shocks were one of the first things to go on my new '11 RKC, went with 2-2B's
Old Nov 4, 2011 | 08:37 AM
steve047's Avatar
steve047
I will finish this review sometime in the future. I'm going to have my Hip replaced November 7th.
Old Jul 6, 2012 | 02:19 PM
steve047's Avatar
steve047
I'm finally back on my bike. Talked to Howard yesterday and he had me close the damping and come back 14 clicks and put a zip tie on the right shock. Now I'm zeroing in on a great ride. Every time we stop and adjust the ride gets better and better. The ride is so good now and I still have a bit more adjusting to do. My review is: I LOVE MY Ohlin 3-1's
And Howard has always been there to help with the set up.
My new hip loves Ohlin Shocks
Old Jul 6, 2012 | 10:23 PM
porkchopsd's Avatar
porkchopsd
Great to hear Steve, glad the hip replacement went well! I bought the #3 #3's from Howard and installed them last week, what a difference! Should have done this upgrade before my last ride to Sturgis!
Old Jul 20, 2012 | 09:27 AM
steve047's Avatar
steve047
fabrik8r Hi Bro, there has never been plastic spring pre-load collars on an Ohlins. Ohlins uses DelrinŽ collars so the springs can turn easier (reduced friction) when the shock is moving up or down. Some racers use a greased washer on each side of the spring, Ohlins uses a naturally lubricated Dupont material to achieve this. The collars are more expensive to produce. The reason why some people break these is because they "push" the tool in a straight line in place of a circle. The pin moves further out of the hole until it has enough leverage to split the color. Due to the Harley customer base I service, it was decided to go with a traditional aluminum spring collar so when they break he customer knows just what happened.
I use the DelrinŽ collars on my own bike which has the #6 shocks. I take my time and watch what I am doing when setting the spring pre-load. We decided that we change the pre-load collar to our HD clients. We utilize these collars on race bikes.
I did just what Howard describes above. I was 355 miles from home and I cracked the Delrin collar. I called Howard and he was very helpful and he told me what to do so the collar would not come apart and I had a great weekend and made it home. And I'm still riding with the cracked collar. Thanks Howard
jeffbetrollin
Jul 27, 2015 10:10 AM
draggindre
Apr 29, 2014 04:59 AM
harleync
Nov 19, 2012 07:41 PM
ks6c
May 29, 2012 08:46 AM
rg_dave
Mar 25, 2012 05:38 PM
