Turn Signal Options
Old Sep 29, 2011 | 12:16 PM
acd118's Avatar
acd118
Default Turn Signal Options
I don't know what it is with me and turn signals, but I am having yet another issue with my right rear turn signal. I have a 2011 SG with the two rear lights as run, turn, and brake (factory set up). All of the sudden, my run quit working, but I still had turn and brake so I figured it was the filament. I know the 1156 single and 1157 dual filament bulbs break easy if you hit hard bumps so I figured it was just another cheap bulb. When I got home, I popped the cover off and put a new bulb in. Turned on the ignition to make sure it worked and still no run light. I went to take the bulb out and apparently it isn't making good contact with the socket. The bulb works if you push it in but does not work if you take pressure off of it, like if it is just sitting in the socket how it normally would.
Has anyone ever had this happen on their brand new bike? What did you do to fix it?
Also, does anyone know of a LED light that would fit into the factory housing? I would love to have LEDs front and rear to replace the cheap 1156 and 1157 type bulbs. $20,000 motorcycles with the cheapest bulbs possible. Way to go Harley.
Thanks for any help.
Old Sep 29, 2011 | 12:32 PM
DannyZ71's Avatar
DannyZ71
Had it happen with a new truck one time. Take some needle nose pliers, or anything you can fit in there and manipulate the socket to make better contact with the bulb. Who ever put the bulb in initially may have pushed too hard and now there is no contact.
Old Sep 29, 2011 | 12:44 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Give these people a call. http://www.customdynamics.com/ They'll set you up. Really bright. I have them on my Road Glide Custom with the same tail lights you have.
http://youtu.be/Fgzxf2WPgws
Old Sep 29, 2011 | 01:08 PM
sanlyn's Avatar
sanlyn
I picked up LED versions of the 1157 and 1156 bulbs at the local Autozone. No issues with them, and they are brighter.
Old Sep 29, 2011 | 04:31 PM
Cornel's Avatar
Cornel
I have these on my 2012 Street Glide. They look really good on, or off and the fit and finish is flawless. Piece of cake to install also. They make them for the front and rear.
http://www.kuryakyn.com/Products/159...al-Conversions
Old Sep 29, 2011 | 05:13 PM
zeppelin316's Avatar
zeppelin316
Default led tail lights
got the ones from badlands and load eq. very bright and fit great 2010 flhx
Old Sep 30, 2011 | 11:28 AM
acd118's Avatar
acd118
Would you happen to have an Autozone part number please? I have been all over their website and I can't find anything like that.
Old Sep 30, 2011 | 12:05 PM
sanlyn's Avatar
sanlyn
The rears were the 1157R, Jam Strait/Red dual element super bright LED bulb. Don't remember the part on the front.
Old Oct 3, 2011 | 11:54 AM
acd118's Avatar
acd118
Thank you Sanlyn. I will check them out.
Doug W
Jun 16, 2018 01:15 PM
Bigdave12768
Jan 7, 2013 04:49 PM
BlackPearl#1
Sep 25, 2012 08:02 AM
homyakchik
Mar 10, 2009 03:14 PM
Motown_HOG
Jul 14, 2008 01:47 PM
