Comparing Air Cleaner KIts
Old Oct 28, 2011 | 08:01 PM
Freebee's Avatar
Freebee
I have the FuelMoto offering the hardware is the updated SE kit. The filter element is Fabric (washable) like the K&N.
I think it was like $120 shipped to Texas
Old Oct 28, 2011 | 11:53 PM
PDDGM's Avatar
PDDGM
I have a power commander and am guessing I will need to download a map for the new air cleaner. Right now I am running stock pipes and mufflers, looked at all the maps available and don't see on for just the air cleaner upgrade. Will I have to remap, or will the ECM adjust for the additional air...If I have to remap, guess I will have to contact PC or fuelmoto for a map...Thanks for the input...
joe
Old Oct 29, 2011 | 01:47 AM
Ronp42's Avatar
Ronp42
Account Retired
Originally Posted by Timmy B
Over the course of a year on this site I spent much time wondering the same. I went SE becuae it is an HD part. I´ve not been let down, but there is always soemthing better. What matters is what you like and quality of the part. I like the SE. heard more negative stuff about the Arlen stuff, both are made in japan, if that bothers you, Doherty machine is the way to go, but it is $$$
Made in USA is stamped right on the front of the Arlen Ness BS filter
Old Oct 29, 2011 | 04:39 AM
emwolb's Avatar
emwolb
doherty makes a great one that usually makes the best torque and horsepower. i can't remember what they call it, but it's very similar to the arlen ness big sucker, screamin eagle stage 1 air cleaner, and others. it does have a better intake venturi for flow though, according to american iron magazine. it has a snap in ring if i remember right. i'm using a stage 1 harley backing plate with a zippers 5/8" deeper element on my built 103 and it flows just fine. no oil drips, but that's not caused by the air filter. there's a myst free doherty product that'll cure that drip.
Old Oct 29, 2011 | 08:33 AM
FenderGuy53's Avatar
FenderGuy53
Originally Posted by PDDGM
I have a power commander and am guessing I will need to download a map for the new air cleaner. joe
Joe, in a combustion engine, it is vitally important to maintain the delicate balance between air flow and fuel flow, known as the A/F ratio (air/fuel ratio). The rule of thumb is: Whenever you change the air flow, you change the fuel flow.
Will the ECM adjust for the additional air...joe
The ECM is capable of adjusting to certain operating conditions; however, I'm not certain of what those conditions may be. I'll let the experts chime in on this one.
Old Oct 29, 2011 | 08:51 AM
Indianspringsaz's Avatar
Indianspringsaz
Arlen Ness BS filter is the one you want.
Old Oct 29, 2011 | 10:03 AM
Chunker's Avatar
Chunker
You didn't ask about this but here's my $.02. I have the V&H VO2 naked which uses the stock cover, It has a K&N style, their own version, washable/oilable filter element.
Old Oct 29, 2011 | 11:15 AM
07fsxt's Avatar
07fsxt
Originally Posted by SteveinNKC
I took the stealth (or cheap) route. I bought K&N filter for the stock harley air cleaner. Then drilled as many 3/4". 1/2" and 1/4" holes I could in the existing air cleaner back plate. All on the back or bottom, so you can't see them when looking at the bike standing near it. I did buy a stock back plate take off in Ebay for less than $25, so I could go back to stock if needed. I spent less than $100, the bike looks bone stock, seems to function fine in Stage 1 mode, and has a cleanable K&N air filter.
What I did is an old Zipper's trick, the guys there told me about years ago.
If you want the stock look, what I did is a decent option, if you want a different look, then what I did is not for you.
I did the exact same thing. Works great.
Old Oct 29, 2011 | 12:31 PM
hougz79's Avatar
hougz79
Originally Posted by Heavy D
I put a Zipper's Maxflow on my 2010 FLHTC, along with SE Fatshotz. I bought the Xied-10 but haven't put it on yet. I asked my HD dealer about the download, and he told me since the Cat is in the headpipe, there is no download available on 2010-newer bikes. He said if I plan on doing anything else like cams, etc then I would be better off to save the $150 and put it towards a fuel processor.
Your dealer is an idiot. Changing from stock to a highflow air filter does in fact require a download at a minimum.
As far as to the OPs question. I went with the AN because I could get different color back-plates for the same cost (chrome or black are additional purchases with the SE), and the SE uses a paper filter. Other than that they are totally comparable as far as performance. I have had zero issues with my AN thus far. I would recommend.
Old Oct 29, 2011 | 12:42 PM
run1fsr's Avatar
run1fsr
I took the stealth (or cheap) route. I bought K&N filter for the stock harley air cleaner. Then drilled as many 3/4". 1/2" and 1/4" holes I could in the existing air cleaner back plate. All we on the back or bottom, so you can't see them when looking at the bike standing near it. I did buy a stock back plate take off in Ebay for less than $25, so I could go back to stock if needed. I spent less than $100, the bike looks bone stock, seems to function fine in Stage 1 mode, and has a cleanable K&N air filter.
I did the same thing and saved my $$$ (poor mans Stage 1) ... Bike Runs Great !!
