103 piston repair
Old Oct 29, 2011 | 10:56 AM
Texas Rider 3's Avatar
Texas Rider 3
1st Gear
Default 103 piston repair
I have a 2011 Ultra Classic Limited (103) with 3000 miles. Started blowing oil and my local dealership informed me the piston, rings, and cylinder need to be replaced on the back cylinder. Good news is this is under warranty. Any concerns I should have for this repair...future problems, etc.? Question for mechanics - should both cylinders be repaired? Concerned if only one is replaced - one with new parts and the other with 3000 miles. Thanks!
Old Oct 29, 2011 | 11:18 AM
vduzin12's Avatar
vduzin12
no worries your under warranty
Old Oct 29, 2011 | 11:23 AM
mkguitar's Avatar
mkguitar
welcome to the forums
I'd be interested in the cause of the problem- did they have any explanation?
Mike
Old Oct 29, 2011 | 11:44 AM
speakerfritz's Avatar
speakerfritz
asked them to provide you the measurements for the ring end gap verification and the valve to piston clearance. These are measurements indicated in the install instructions . If these measurements are not done, you risk a possibility of having a re-occurrence of part failure.
Old Oct 29, 2011 | 04:21 PM
Dr.ultra2010's Avatar
Dr.ultra2010
wow !!!! let us know what the tech says?????
Old Oct 29, 2011 | 05:31 PM
Pelonz's Avatar
Pelonz
Welcome to reality and the HD Forum
Old Nov 12, 2011 | 12:38 PM
Texas Rider 3
1st Gear
Wanted to post an update on my repair. The dealership checked both cylinders and determined the rear cylinder was bad but the front was within spec. Therefore, they were only going to replace the bad cylinder. However, I spoke to the service manager and he contacted HD about my concerns. HD indicated they were not going to replace the front cylinder, but my dealership stepped up to the plate...they are going to replace both cylinders. I will continue doing business with this dealership.
Old Nov 12, 2011 | 01:48 PM
mtclassic's Avatar
mtclassic
being they have it apart you might think about having some head work done. At the very least I would ask them to use a .030 headgasket.
Old Nov 12, 2011 | 02:18 PM
caspr2's Avatar
caspr2
What is the name of this dealer. When one goes and does the right thing like this you need to bragg up on them a little. We sure hear all the bad stories.
Old Nov 12, 2011 | 02:52 PM
mgmmgm's Avatar
mgmmgm
Glad to hear that your dealer went above and beyond the MoCo stance on your issue.
