Recall switch issue anyone else?
Old Oct 29, 2011 | 10:15 PM
L-Premo's Avatar
L-Premo
Default Recall switch issue anyone else?
I am wondering if anyone else has experienced the below issue after having the new switch installed.
After picking up bike from having recall brake switch replaced, it seemed like the brake pedal sat lower than before and seemed a little mushy. So didn’t think much of it. While leaving the dealer just to check the feel of the brake, I pressed the rear break hard enough for a quick stop. When I did, I felt and heard a couple of clunks. Each time I repeated this I felt and heard the same thing. At first I thought maybe it was the ABS pulsation, but I never pressed the brake as hard as I could as if doing an emergency stop.
So I returned to the dealer and explained the symptoms to the service desk. He had the tech who did the fix check it out and he was able to repeat the symptom and said he never felt anything like that before. So they had the senior tech take the bike for a ride and he experienced the same thing. So I left the bike because they were going to bleed the brakes manually and they also said that the RGU also required a computer check for the bleed also.
Got a call back several hours later from the service desk asking if I could leave the bike overnight? Seems they had done the recall fix on several other bikes today and some of those bikes were experiencing the same symptom. They want to research what the cause is and fix it or find out if it is a common thing with the new switch.
Personally I don’t think there is or should be anything common about brakes clunking when pressed.
Old Oct 29, 2011 | 10:20 PM
Port Dawg's Avatar
Port Dawg
Hmmmmm. I had recall done and yes mushy brake.......brought it back on right away...he rebled brakes and brake seemed firmer......I rode around lot using just rear brake and when pressed hard it clicked and released a,couple of times but stopped me.......sure this isn't just the abs doing its job??
Old Oct 29, 2011 | 10:57 PM
LimitedLou's Avatar
LimitedLou
I had a rear brake switch replaced over a year ago and had to take back and had them re bleed system, been good ever since... Now I guess I still have to bring in for another ??
Old Oct 29, 2011 | 11:01 PM
hog95023's Avatar
hog95023
As a matter of fact I had mine replaced and when i tried to stop I felt and heard a clunk
I thought something fell off of my bike it only .happened once
Old Oct 29, 2011 | 11:11 PM
fireaxxe's Avatar
fireaxxe
There is air in the brake system and needs to be bled out.
Old Oct 29, 2011 | 11:15 PM
ke5rbd's Avatar
ke5rbd
The engine braking in lower gears and the rear brake at the same time will cause the ABS to activate on mine. If you pull the clutch in before braking in lower gears mine doesn't do it. The mushy part is air in system.
Texas Fat Boy's Avatar
Texas Fat Boy
You will need the new switch now too. I had mine replaced in June and it was the same switch, not the new one.
Old Oct 29, 2011 | 11:23 PM
LimitedLou's Avatar
LimitedLou
Yes, and thanks. Not in a hurry, Harley supposed to send out something in mail I hear .. Everything fine..
Good Looking Bike...
Old Oct 30, 2011 | 06:59 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Not worth the aggravation...If and when my brake lights stop working, I'll replace the switch myself but after I buy it at a local auto supply store....Did they have this many issues during the AMF days LOL.....
Old Oct 30, 2011 | 07:59 AM
ColoSpgsMark's Avatar
ColoSpgsMark
I asked my dealer yesterday about whether they'd seen any failures. Just one so far, but in this case the switch cracked, brake fluid leaked out, and the owner lost use of his rear brakes. He indicate that or brake light electrical failure could be the outcomes. Not worth waiting on if you ask me. He'll give me a ring when they get their next batch of replacement switches.
Mark
