2005 Road King cold weather problem
- Machined to exact tolerances for improved performance/reliability
- Patented QUICKSHOT 3 technology for precise/consistent fuel metering (QS3 chamber completely fills with fuel, eliminating trapped air in system, for accelerated fuel delivery)
- 25% more fuel capacity plus added bleed capability allows for solid fuel delivery 100% of the time
- Dual Check Valves, new ball & spring system keeps fuel dirt from clogging system, second valve located at sprayer for immediate response of fuel spray
- "ON THE FLY" external leak jet adjuster maximizes fuel volume/duration of squirt for all conditions (turn out for hot days/high elevations - turn in to enrich for cold days/low elevations)
- Stainless plunger rod & 5% stiffer activation arm spring for consistent spray response
- Precisely angled Twin Hole Sprayer enhances fuel velocity/atomization for increased roll-on acceleration
- Removable main jet cap for quick access tuning
- Predictable, smooth, instant throttle response - similar to EFI
- Improved low end performance, quick cold starts, no more hesitation/bog/stalling/backfiring
- Boyesen Unconditional Guarantee - complete refund if not 100% satisfied
http://www.boyesen.com/twinshot-vtwin
http://www.hotbikeweb.com/tech/1004_...t/viewall.html
If you are SURE that you are getting proper mixture, then if the rear is sooted up perhaps you have an oiling or misfire problem
if the bike runs better when warm, check for intake leaks--- that is more likely. when the bike is running like crap, spray wd40 or even water ( narrow tube) at the manifold to head joint- if the idle picks up and smooths out- you've found the problem
make sure there is no water in the float bowl- there is a drain accessed with a screwdriver from between the cylinders- seen from the left side of the bike--- prepare to catch the draining fuel from the thin black tube.
the idle adjuster you reference is handy but does no magic the stock adjuster doesn't do with a screwdriver.
the best laid out CV carb tuning and modding info is at nightrider.com in the bike tech section.
I have set up my cv carbs ( many) using this method to great result.
MOST of the products sold for the carb are only useful to a rider who is familiar with function and tuning the circuits of the carb ...not the novice.
idle needle controls the amount of fuel added to the air at idle
low speed jet ( usually a .45) controls 1/8 to 1/4 of throttle ( idle circuit is still also adding fuel)
needle controls to about 3/4 throttle ( in conjunction with the main jet size and the other circuits are in operation as well)
Main Jet from 3/4 to full throttle-- again the low speed and idle circuits are still adding fuel to the air stream
the accel pump shoots gas at the carb throat from that little brass tube when the throttle is rapidly opened--- a few quick shots with this when starting can makes things sooty
are you using the enricher? ( it's not really a choke on these bikes)--- and giving it a couple minutes to warm up before starting off?
tailpipe smoke
white on acceleration: piston rings
white on decel: valve seals
Black--- over rich mixture---- (does this happen at all throttle settings or only some?)
if you end up opening the carb, the float bowl screws are tight and you may deform them when removing ( needle nose vise grips work to break them loose), replace with 4 mm allen heads and put some antiseize paste on the threads
Stay out from under those crumbly bridges, Mike
( - "ON THE FLY" external leak jet adjuster maximizes fuel volume/duration of squirt for all conditions (turn out for hot days/high elevations - turn in to enrich for cold days/low elevations)
A properly operating CV carb is self adjusting for air density changes due to altitude or temperature
CV is "Constant Velocity" the air stream is keep at a constant velocity by the vertical sliding plunger
The CV is awesome, supporting motors over 100 HP--- tuning and mods require only $20 of parts and a pocket full of smarts--- no aftermarket add on will replace that
Mike
