99 Ultra classic *need bigger starter*
Looking to get a starter for my fathers HD ultra classic.
its a 99 Vtwin (twin cam 88) has stroker crank big bore cyls high compression, ported head cams ext... (i know they had to tune it down a slight bit cause he didnt want to race fuel or what not.
He does have the decomp valves on the cylinders and all.
Anyways. He has a stock starter and its not working for his set up. Most of the time he has to use a jump start pack to juice the battery some more to get it going after a good few tries.
Im looking into buying one for him for his xmas present but I don't want to buy the wrong one.
How many cranking KW should I aim for on the starter and where can i find a good priced one? will he need a bigger battery for the bigger starter?
ive seen them go from 1.2kw to 2kw.
I tried doing a search but im not that knowledgeable in these bikes so not sure what works for his bike and what doesn't.
Biggest one I found on ebay so far was 1.4kw for 168 or somewhere in those lines. But im thinking on going bigger.
I was looking at something like this... but what gets me is ""Fits some stock applications on Big Twins where 3/4 longer body is not a problem"" i got no clue if it will fit or not...
http://www.ebay.com/itm/ULTIMA-START...#ht_2407wt_698
Thanks and appreciate any help!
If you need more detailed information just let me know
Cheers
Jesse
2.) KW only signifies how much electrical power the motor can take from the battery--- it has NOTHING to do with the turning power they produce--- if you've ever been around motors for swimming pool pumps you know that those motors are rated in horsepower
3.) the stock H-D starter holds up very well--- think about having it serviced.
Clean up the commutator, replace bearings, rebuild the solenoid or clean up the contact disc
4.) battery good- test it, does it put out over 400 CCA- ? the Deka AGM is a good battery
replace the cables, make sure the ground connections are clean and tight- if there is not one there add a ground strap between the rubbermounted motor and the frame ( usually from the inner primary to the frame near the swingarm)
make sure the bike is properly tuned to fire when starting--- is the ignition firing on 1st rotation, or on the 2nd or 3rd?
Carb or EFI- ?
Timing retarded
with compression releases starting should be easy-- and are they closing 1st, 2nd, 3rd rotation?
Flywheel weight ?
when a motor stops ( any motor) it ALWAYS stops on the comp stroke, when starting the motor often has to be turned past TDC to get momentum ( and draw air/fuel) to start.
On my hicomp bike I flick the starter switch to get the piston over, then press and hold to start.
IF the starter whines and the motor is not turning- stop...the windings will burn up
BTW welcome to the forums
mike
It got tuned by a HD dealership on a dyno.
All i was able to get out of my dad was that the flywheel is a Screaming eagle 110.
Not sure on timing
It sounds like the comp release are only closing after a few turns from the sound.
He just inspected the wiring making sure everything had a clean ground and so on checked out good. (as far as i know)
The starter doesnt whine away, it rolls the bike over then "locks" after a sec or two if it doesnt start up
Ive seen him tap the starter to roll the bike over then get at it. sometimes it works sometimes it dont... its a big hit or miss. But its been getting harder to start as time goes on...
Thanks for the quick response!
He just told me it wont even roll over at all without the jumper pack now...
With the jumper pack its having issues but manages to turn it over. seems like a hit or mis now for it to start. Starter likes to lock up after a couple turns of the crank.
But like i mentioned... it got worse over time. except the starter always seemed to have "locked" not whine away
I know the starter is stock from 99 and never been touched though so do you guys think just rebuilding the starter should fix the issue?
110 TQ on back wheel 95HP on the dyno he ran it on
Appreciate all the help so far!
Thanks
