View Poll Results: With a Harley Cruiser (or any make/model with this setup), which do you believe INCRE
Ride with you high beams on.
20
14.29%
Big light in the middle AND both spots on.
120
85.71%
Voters: 140. You may not vote on this poll
Visibility: LIGHTS
Old Oct 21, 2014 | 10:30 PM
  #31
dirtracin23's Avatar
dirtracin23
Originally Posted by Groucho1
Unless you bypass it, then you can have both the spots and high bean on.
I did it and can't get why they don't just come that way.
I believe some states vehicle codes say that with high beams on no auxiliary lights are allowed to also be illuminated.
Old Oct 22, 2014 | 09:09 AM
  #32
bigheadted's Avatar
bigheadted
Hi beam and spots during daytime. Spots are bright yellow H-3 type with upgraded bulbs and all lights are adjusted to suit me for night riding.
1 in probably 600 cars will flash me, had a few drivers complain about my bright lights and I ask them "did you see me, ?? Good that is the purpose as I need every advantage possible to be seen by drivers" . Have gone by dozens of lawmen even a notorious ***** CHP biker hater several times without issue.
Old Oct 22, 2014 | 02:15 PM
  #33
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by Tooltech
Pre 2014 there is a simple jumper harness that allows spots to run with high beams.
2014 a simple BCM flash (mine was free) allows it.
Yea, but even with that kit you have to still cut and splice wires. Which does beg the question of the purpose of the kit then.
http://www.harley-davidson.com/app-c...ts/-J05535.PDF
Old Oct 22, 2014 | 05:32 PM
  #34
SSteve's Avatar
SSteve
I keep the high beam (LED) on along with the passing lights (LED) during the day, yes I have the plug and play loom adapter, works great. At night I generally use the low beam with the passing lamps. Works for me. I like being seen, just might be enough to make a difference.
Old Oct 22, 2014 | 05:40 PM
  #35
Markusm's Avatar
Markusm
ride with spots on at all times
TriGeezer
19
Oct 6, 2018 03:08 AM
fullautomike
Jul 17, 2016 07:04 PM
AmericanMuscle
Dec 4, 2012 08:05 PM
roblack
Sep 2, 2012 01:51 AM
Deadwood Dick
Nov 8, 2011 04:24 PM
