cam score...
Old Nov 30, 2011 | 04:53 PM
mrfikser's Avatar
mrfikser
Default cam score...
I picked up 4 sets of used stock cams with lifters gears, chains from ebay ....one of the sets of cams are se-255 (which is what I wanted for my bike)....score $40 ($54 with shipping)....
Old Nov 30, 2011 | 04:59 PM
Jake72's Avatar
Jake72
Just one set for that price would be awesome. Good score!
Old Nov 30, 2011 | 05:08 PM
mkguitar's Avatar
mkguitar
no way would I install used internal parts on my bike- but that's me.
Mike
Old Nov 30, 2011 | 05:17 PM
Fire-Medic's Avatar
Fire-Medic
Mike
What would the reasoning be? Let's say one of your buddies is upgrading stuff and wants to cut you a deal?
Old Nov 30, 2011 | 05:28 PM
mrfikser's Avatar
mrfikser
Mike
once you put them in the bike aren't they used???...I mean they are only new until you install them, so what diff. does it make???..I can understand something like rings , but cams run on frictionless bearing on all moving areas....or should i just say thank you for helping to keep the price of pre-tested parts down, keep up the good work the economy needs more like you....
Old Nov 30, 2011 | 05:40 PM
mtclassic's Avatar
mtclassic
Ditto, unless there is obvious damage to the cams running surfaces your bike is not going to know the difference.
Old Nov 30, 2011 | 06:07 PM
lionsm13's Avatar
lionsm13
More like cam's scored...?
F-that!!
Puttin' used cams in a $20 K motorcycle?
Let us know how it goes...
Member, an ounce of prevention is worth a POUND of cure..
Old Nov 30, 2011 | 06:12 PM
slothy's Avatar
slothy
used se255 cams in my bike - 11k miles since i installed them and no issues.. put then in when i had 3500 miles on my bike.
Old Nov 30, 2011 | 06:35 PM
mplecha's Avatar
mplecha
I like saving money, but not on used engine internals!
Old Nov 30, 2011 | 07:05 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
as long as there was no damage to them, no problem at all, camshafts are very hard, and unless there is some sort of abnormal wear, run 'em if those are what you want, no harm, no foul. good score on that set
