Squealling front brakes
Old Dec 7, 2011 | 08:05 PM
mudbeast2's Avatar
mudbeast2
Default Squealling front brakes
My front brakes are squealing like little piggies! But as soon as you touch the front brake lever they stop. The stealer says it is normal, another shop says I need floating rotors because the problem lies with my stock rotors because they are polished but I say there stock. I want to try new pads because mine are wearing crooked. What pads do you guys suggest?
Old Dec 7, 2011 | 08:12 PM
Tripp_HPjunkie's Avatar
Tripp_HPjunkie
This is what I use on the front
http://www.jpcycles.com/Product/240-710
It does help to rebuild the front calipers everytime you replace pads( brakes tend to drag alittle) but this is on the old style harley calipers....not so much on the brembos.
later
John
Old Dec 8, 2011 | 05:03 AM
smokindave's Avatar
smokindave
If your pads are wearing "crooked", you may have a piston that is hanging up from crud in it. Another words, one piston is freer than the other. Take off the caliper and take the pistons out, clean the pistons and replace the o-rings. Don't forget the the lube, it comes with the new o-rings and an instruction sheet.
If you don't do this, expect another set of pads to wear crooked and your rotors will warp from the excess heat of rubbing.
Old Dec 8, 2011 | 06:05 AM
EasternSP's Avatar
EasternSP
There was a service bulletin a while back about front squealing brakes. The instruction was to remove the rotors and swap the right for left and left for right so the center pattern was reversed.
For the dealer to tell ya, "That's normal". Ask him why in the world would Harley engineers design the brakes to squeal.
Old Dec 8, 2011 | 08:08 AM
Olde Skool's Avatar
Olde Skool
Try this: http://www.lyndallracingbrakes.com/service_tech.htm
Old Dec 8, 2011 | 08:47 AM
knewt5's Avatar
knewt5
I would investigate this. I had the same problem and the dealership followed the bulletin and the problem was solved. Based on your pic...I think it might help
Old Dec 9, 2011 | 01:16 AM
deepsea's Avatar
deepsea
I just traded up for a 07 road king a week ago and I noticed the squeeling sound from the front brake. Not really a squeeling but a noticable rubbing sound that went away with slight pressure on the lever. I took it back to the dealer and they said it was normal. My rotors were replaced when I bought the bike because they were warped. If this is a common problem why are the dealers saying it's normal?
Old Dec 9, 2011 | 02:21 AM
mkguitar's Avatar
mkguitar
Normal to have a slight metallic "shhhhh" rubbing noise which is reduced when the brake is applied slightly.
if the discs are warped it'll be more apparent
squealing brakes are caused by the pads vibrating when applied.
hard pads are more likely to squeal, but last a long time
soft pads are quieter, shorter life and cause more dirt
squealing is reduced by using an anti squeak paste or rtv silicone to the back side of the pads when they are put on ( this absorbs and dampens vibrations)
collected brake dirt and dust behind the pads and binding pins (on which the discs slide) can also cause noise problems- this needs to be clean and the pins lubed correctly
chamfering the leading edge of the pads 45ş can also help
when replacing pads it is good practice to clean the calipers of dirt and dust and when pushing in the pistons, cracking the bleeder to expel the fluid nearest the caliper as that will be the most degraded.
riders with abs should check the manual for any special procedures
when selecting pads, keep in mind the hard/soft trade offs with either stopping distance should be much the same.
I have had good luck with stock H-D pads on baggers, and also EBC pads on my FXRP.
mike
Sammydogs64
Feb 2, 2014 12:23 PM
tx-skydiver
May 13, 2010 09:26 AM
Mr. Lucky
Apr 3, 2010 06:27 PM
SE120RG
Jul 23, 2009 07:59 AM
Mr Wonderful
Mar 17, 2007 08:09 PM
