Need advice on releasing throttle/Idle cables
Old Dec 10, 2011 | 03:53 PM
bubbas1's Avatar
bubbas1
Default Need advice on releasing throttle/Idle cables
Working on the bike and get to the part where I have to release throttle/idle cables. The book says to just pull the end out of the wheel and slide the cable thru the notch. Been trying for the last hour. They will not come out. The cables are to tight. Kinked the idle one already so I thought I woud ask here before I completely screw it up.
Thanks
Old Dec 10, 2011 | 04:07 PM
mkguitar's Avatar
mkguitar
year and model would help. carb/ efi ?
you have the adjusters ( on the cables up by the throttle grip) all the way in, so that the free part of the cable is as long as possible?
If you need extra length unhook the cables from the throttle grip itself remove the cover ( and switch housing depending on model)
Mike
Old Dec 10, 2011 | 04:24 PM
bubbas1's Avatar
bubbas1
Thanks mkguitar
Its a 06 Ultra EFI
Had a brain fart and never even thought about the adjusters. Just never clicked in my head.
Ok bak at it tommorow because now it beer thirty.
Old Dec 10, 2011 | 04:54 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Make sure you don't drop the tiny little brass cable end barrels. You'll see what i mean, if you drop one
Old Dec 10, 2011 | 04:59 PM
Markymannn's Avatar
Markymannn
Originally Posted by bubbas1
Had a brain fart and never even thought about the adjusters. Just never clicked in my head..
Yeah you would think they could include that bit of info. I had to have my kid standing behind me to drop that advice on the old man
Old Dec 10, 2011 | 05:55 PM
SpiderPig's Avatar
SpiderPig
They just disappear "POOF" never to be seen again!
Old Dec 10, 2011 | 06:55 PM
bubbas1's Avatar
bubbas1
If I would have continued messing with the bike today I can gaurantee I would have lost the end. Just the way my whole day went. Figure I have to have a fudged up day once in awhile to appreciate the good ones.
Old Dec 11, 2011 | 07:19 AM
1flhtk4me's Avatar
1flhtk4me
Yep!Spent a half hour looking for one once.I did find it.
Old Dec 11, 2011 | 09:17 AM
coolerman69's Avatar
coolerman69
Hint.....As your pulling that cable end out have a dollop of axle grease on a free finger and dab it on the little brass bast@#d so when you drop it it will stick and not bounce!
Old Dec 12, 2011 | 01:02 AM
bubbas1's Avatar
bubbas1
Got them off with no problem. The only thing that went for a ride was the c clip for the cruise control. Have to go to the dealer anyhow so no big deal.
Springer91
May 24, 2015 10:33 PM
DrRude
Sep 4, 2014 03:47 PM
TCC2
Feb 27, 2012 01:12 AM
piercings4_u
General Topics/Tech Tips
Apr 8, 2011 03:47 PM
seamonster
Jul 2, 2010 05:48 PM
